What the?... can anyone tell me why this happened
- cas.vanderwoude
I am a new '79 KZ1000 owner. Bought this bike a couple weeks ago and have been slowly cleaning it up. PO tells me he had the carbs cleaned, rebuilt and jetted by a specialist on the mainland. But it ran like shit - only capable of about 4500rpm in any gear and I was pretty sure this was a carb issue.
There is a leak at one of the intake boots and #1 and #4 dribble from the overflow when parked.I rode it daily to work (4 miles, max 50mph) and it could barely do that. Mileage was 30 mpg. Before taking the carbs off and fiddling with them, I thought I'd replace the points, set timing and wait for my new pipes to arrive and get fitted. I have a few other bikes so was in no hurry. Also wanted my mechanic to re-shim the valves first.
Getting to the good part... I noticed the pod filters were a bit old so bought a new set. The old pods look like they had been sucked inwards somehow - instead of being conical, the edges were concave. Anyway, I fitted the carbs and rode to work this morning. The old girl ran like a rocket! At about 4000 rpm, instead of stumbling and carrying on, it hit some kinda 2 stroke power band and rocketed to 7000 rpm. I was not expecting this and almost fell off the back of the bike! I may have wet myself just a little bit...
Although rather delighted, I'm also more than a bit curious as to why? Can anyone help me here? Any thoughts appreciated. Mechanic reckoned it was running lean before, but I thought maybe rich. Plugs were not black or white but a mid brown. What the f#%K has caused this rather nice change in behaviour? Also, do these monsters have a power-band like response in this rev range? I rode a Suzuki GS1000S for years and it was not at all like that!
Motorcycles are like underpants - you should have one for each day of the week
- MFolks
- Thank you received: 540
- wireman
- Thank you received: 299
Is the motor stock internally,maybe differant set of cams that come to life around 4,000?
Ive got an old 1170 motor wrapped up in my barn that would run like an absolute dog till about 6500 when it would hit its happy spot and suddenly come to life and try to toss ya like a bull! :sick: :woohoo:
- cas.vanderwoude
WOW! I've ridden big quick bikes before. A Suzuki GS1000 Wes Cooley Special was no slouch back in the day (and probably even now). But this MOFO just scares the living sh#t outta me. My frigging legs were waving around in the slipstream - it was all I could do to hang on! (note to self... gotta replace those police bars with some flat ones so I have 1/2 a chance of hanging on).
- wireman
- Thank you received: 2829
- Motor Head
- Thank you received: 391
- mark1122
- Keep twisting it
- Thank you received: 109
Motor Head wrote: I wonder if the old set of pods had covered the Air Bleeds at the Airhorn/ Bellmouth of the carb, causing the excessive rich running?
X2
u may have some aftermarket cams in there. they can cause a sweet spot like that .
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- loudhvx
- Thank you received: 1616
Paper pods look almost exactly like the gauze type, but are much cheaper, disposable, and require no maintenance.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- cas.vanderwoude
I'm still not sure what the issue was. Attached is an image of one of the pods. BUT - I am now very much in love with this bike. She seems to have 2 personalities - one below 4000 rpm where she is sedate, agile, graceful and restrained, then the devil comes out at around 4500-5000. At this point, hang on, don't wet yourself, brace (cos otherwise you will pop a disc in your neck) and she will go like the clappers! I'm too old for this but once over the 4500 limit, she turns into a beast, I have a smile frozen on my face and I just wanna go real real fast. One scary bitch!
Maybe the cams are after-market. Whatever, its a real rush!
[attachment:1]IMG_3541.JPG[/attachment]
dl.dropbox.com/u/17898942/IMG_3541.JPG
- 4TheKZ1000
- Visitor
loudhvx wrote: Maybe the old pods were actually the paper type, and not gauze. Then if someone oiled them, they would be clogged. This would also explain the caved-in look, and 4500 RPM limit.
this caught my eye +1
- trianglelaguna
- Thank you received: 235
MFolks wrote: Possibly a backfire melted the pods(If they were the foam type),but if they are the K & N gauze type, I have no idea of how they changed shape.
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
