one carb is hissing??
- whitskz
22 Oct 2012 20:21 #555254
by whitskz
one carb is hissing?? was created by whitskz
These stupid carbs.... Today on the number one carb I have a pronounced hiss, not constant but with the rpm or stroke of the motor. It was always faint but i attributed that to the pods. What could/should I check? Compression is 145 across all 4 and carb sync was done a week ago. Thanks, these vm26 on a 78 1000
- Motor Head
- Thank you received: 391
23 Oct 2012 09:29 #555340
by Motor Head
Replied by Motor Head on topic one carb is hissing??
Vacuum leak. Check your caps and vacuum lines for the nipples used for balancing. Might have a hole/ crack in one. Or a leaking carb holder/ manifold.
- whitskz
23 Oct 2012 10:25 #555344
by whitskz
Replied by whitskz on topic one carb is hissing??
yeah that was my thought too but its coming from the throat of the carb in this case.
