Inverted float levelling.
  • rdhussey
  • rdhussey's Avatar Topic Author
19 Jun 2006 06:52
#55468
What it the spec for the distance from carb body to float bottom when dry-levelling the floats in a 34mm cv carb?
82 kz750 sceptre
  • steell
  • steell's Avatar
Re: Inverted float levelling.
20 Jun 2006 12:10
#55755
I have not seen an actual spec for that, it seems like Kawasaki gets a kick out of making people do things the hard way :(
  • wiredgeorge
  • wiredgeorge's Avatar
20 Jun 2006 12:29
#55763
I don't remember the spec as I don't do setting the level of gas that way; especially on a BS series carb as it is a waste of time. Most of the floats have been bent up over the years. Set the floats using the service fuel level method and then go back and note that they will be off 3 or 4 millimeters as far as their float level goes... If I had new pristine floats to work with, I would set the float level in a heartbeat... I even have a special tool to do it; its just that it isn't reliable enough.
  • neilage66
  • neilage66's Avatar
20 Jun 2006 15:01
#55797
I have different model carbs than you have, but I did the inverted float "eyeball adjustment" while rebuilding/cleaning/re-jetting. Three out of four carb floats were set the same, so I "bent up" the other float tab to match the other three. All four were air tight too which is always necessary. Again, I lucked out 'cause I haven't touched them since and she runs nice and doesn't leak fuel or seem to be troubled. :P
I know this is not a very professional method of adjustment, but it seemed "horse sense" at the time and has seemingly worked out ok. :)
