- Thank you received: 2
Carb slide adjustment
- lemo32
- The Price of Cool aint cheap
17 Oct 2012 23:13 #554433
by lemo32
1979 kz 1000 06 katana 750
Carb slide adjustment was created by lemo32
got some vm 26s and was wondering if the slides on the carbs should be all the way closed in a start mode, mine are slightly raised.
- kawasaki mike
- kawasaki mike
- Thank you received: 4
17 Oct 2012 23:49 #554439
by kawasaki mike
Am addicted to Z1's and kz 900's have an el camino, fly rc helicoptors and am strung out on horsepower.
Replied by kawasaki mike on topic Carb slide adjustment
that depends on how fast the idle speed is set. should have some clearance. on the cut a way side there will normally be more (filter side of the carb)
- Thank you received: 2098
18 Oct 2012 10:38 - 18 Oct 2012 10:39 #554487
by Patton
Replied by Patton on topic Carb slide adjustment
After proper bench sync and running sync and idle adjustment, throttle should remained fully closed to enable the enrichener circuit to correctly function.lemo32 wrote: got some vm 26s and was wondering if the slides on the carbs should be all the way closed in a start mode, mine are slightly raised.
Last edit: 18 Oct 2012 10:39 by Patton.
