fuel in vacuum caps normal?
- whitskz
15 Oct 2012 23:27 #554105
by whitskz
fuel in vacuum caps normal? was created by whitskz
Every time I pull the vacuum caps on the carb holders to check sync they are full of fuel, is this normal? Just struck me as odd given this is my first carb'd inline 4 motor. Motor is a 78 1000 with vm26 carbs, thanks
- Motor Head
- Thank you received: 391
16 Oct 2012 00:59 #554119
by Motor Head
Replied by Motor Head on topic fuel in vacuum caps normal?
If the vacuum ports are underneath the carb holders/ manifolds, then fuel will end up there. Normal.
- loudhvx
- Thank you received: 1616
16 Oct 2012 22:36 #554264
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic fuel in vacuum caps normal?
+1Motor Head wrote: If the vacuum ports are underneath the carb holders/ manifolds, then fuel will end up there. Normal.
1981 KZ550 D1 gpz.
Other links.
- Thank you received: 1656
17 Oct 2012 10:42 - 23 Jan 2013 11:03 #554313
by martin_csr
Replied by martin_csr on topic fuel in vacuum caps normal?
I wonder if the ethanol in fuel will have any effect on the rubber caps? not really worried about it, just a thought.
Last edit: 23 Jan 2013 11:03 by martin_csr.
- whitskz
17 Oct 2012 11:33 #554318
by whitskz
Replied by whitskz on topic fuel in vacuum caps normal?
im sure it would, it messes up everything else. would be nice to find some really good ethanol resistant caps.
- Motor Head
17 Oct 2012 22:29 #554418
by Motor Head
I haven't seen it bother any of the Factory caps yet. They seem to hold up to the Deathanol, like the choke plungers and diaphragms. Pretty tough stuff, as there are a lot of fuel components being eaten by the crap.
- Thank you received: 2098
18 Oct 2012 09:01 #554474
by Patton
Replied by Patton on topic fuel in vacuum caps normal?
