need help bad
- kz440rat
and i dont want to hear that its the pods or pipes i know there is a way to make this bike run fine with out the stock air box i have seen this bike bobbed out and no one has the stock air box
- Kraz1
- BRABBIT04161991
- kz440rat
- kz440rat
- Kraz1
> KZ440 Ignition
- peavylotus
- Movin on up
- Thank you received: 15
www.iwt.com.au/mikunicarb.htm
1980 KZ 1045 LTD Currently Workin' It Out
- Thank you received: 2829
Attachment 00000_2012-10-11.jpg not found
- Nebr_Rex
- Thank you received: 300
And they don't have the stock carbs they're running a slide type carb that doesn't have the vacuum diaphragm.
As for pods,if they block the air bleed ports you'll never get it right.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
