- Thank you received: 2
Carb Questions
- 2bskor
04 Oct 2012 11:45 #552413
by 2bskor
1979 KZ1000ST (Canadian) Electronic Ignition, 4 into 1 header,K&N air filter
Carb Questions was created by 2bskor
I have a kz1000st (Canadian Model) I am gathering stuff to overhaul the bike this fall. I wanted to get a float level guage but I am unsure exactly what carbs i have. I see two different tools listed on z1 website. Any suggestions?
- razzman
- Thank you received: 1
08 Oct 2012 19:50 #553129
by razzman
Ride like you're invisible,
Spyder
Replied by razzman on topic Carb Questions
The carbs you most likely have are Mikuni VM28SS pumpers. They were OEM on 1979-80 Models of the shaft drive. Sevice fuel (clear hose method) is, by book, 4 plus or minus 1 mm. The clear tube method is all I use on all my builds. You can set them dry at around 24mm and then check via clear tube (wet) method and make final adjustments as necessary.
Spyder
Spyder
Spyder
- DiamondSkyBlue1000
- Thank you received: 40
08 Oct 2012 20:02 #553139
by DiamondSkyBlue1000
Replied by DiamondSkyBlue1000 on topic Carb Questions
Hey Spyder!
Everyone, meet Spyder. He rebuilds carbs for the KZ. He rebuilt my VM26 a couple of years ago. Damn good job, too.
How have you been?
How have you been?
- 2bskor
08 Oct 2012 20:24 #553149
by 2bskor
Replied by 2bskor on topic Carb Questions
Perhaps. I know I've seen carbs on eBay that say they are from a shaft but they seem to have an accelerator pump visible which mine doesn't have. With the clear tube method there must be a fitting that screws into the carb drain bowl I take it.
The lilts I have coming have needles and jets etc. what would a main jet size be for a 4 into 1 be. I took the carbs off today and they are a real mess. The bike has been eating gas and running really rich.
- jonnybravo
- Banned
- Thank you received: 18
09 Oct 2012 06:06 - 09 Oct 2012 06:13 #553224
by jonnybravo
www.kzrider.com/forum/21-tools/385849-du...oat-level-tool-setup
Replied by jonnybravo on topic Carb Questions
make ur own, any hardware plumbing section has the stuff, u can do it for about 5 dollar2bskor wrote: I have a kz1000st (Canadian Model) I am gathering stuff to overhaul the bike this fall. I wanted to get a float level guage but I am unsure exactly what carbs i have. I see two different tools listed on z1 website. Any suggestions?
Last edit: 09 Oct 2012 06:13 by jonnybravo.
