- Thank you received: 5
removing pilot jet? chrome polish?
- jbeebe1
Also, i cleaned up the diaphragm caps with aluminum foil and water (after the current picture was taken), but does anyone know of any good chrome polish?
79 Honda 400 Hondamatic
79 Honda CB650
81 Honda CX500
81 Honda Passport C70
others coming in and out all the time!
- roy-b-boy-b
- Thank you received: 103
- Thank you received: 2098
That's the "Pilot Adjust Screw" to regulate the air/fuel mixture in the carb pilot circuit.jbeebe1 wrote: ...81 440B2...can't seem to get the pilot jet and screw out...It's the one on the "right" of the "upper" carb in the pic, where its set down in. What does this even do? The fsm says when i put it back in I have to put some compound around it to keep it in or something?....
There's also a spring plus an o'ring and a washer that fit onto the screw which stabilize the screw in its position, keep it air-tight, and allow for smooth rotation of the screw.
Following correct assembly, it likely doesn't require any goop.
The carb parts diagram may be viewed at kawasaki.com, which includes numerous including parts diagrams, part names, part numbers, models sharing same part, availability, etc. Here's a link for help with navigating the site and finding information.
kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
Much helpful info may also be found at:
www.armbell.com/forum/index.php?c=6&sid=...571a51a&mforum=kz400
and
www.kz400.com/
A manual may also be viewed and downloaded:
home.comcast.net/~loudgpz/GPZweb/Mnls/Mnls.html
To remove the stuck screw, would suggest soaking overnight, or a few days if necessary, with Kroil, Liquid Wrench, PJBlaster, or a mixture of ATF/acetone or ATF/kerosene.
Then, after assuring the carb is completely free of any gasoline or gasoline residue, apply heat with a torch directed around the screw immediately before attempting to break it loose.
(Probably needs a new o'ring anyhow.)
Not being a bone-fide 440 rider, roy won't be awarding any points. :lol:
- jbeebe1
Thanks for the response. in the fsm it states to "turn in the screw and count the number of turns until it seats fully but not tightly" and then remove. When reassembling I screw it all the way in, then back it out that number.
Should i follow that procedure?
79 Honda CB650
81 Honda CX500
That's to help return the screw to the same adjustment position it was in before being removed. And presupposes a screw that isn't frozen and requiring special techniques simply to break it loose.jbeebe1 wrote: ...in the fsm it states to "turn in the screw and count the number of turns until it seats fully but not tightly" and then remove. When reassembling I screw it all the way in, then back it out that number. Should i follow that procedure?
Imo, the first priority would be breaking the screw loose without damaging it, according to the suggestions already noted. Let us know your progress with regard to removing the screw, whether further more serious efforts are needed, such as possibly resorting to reverse drilling, etc.
Meanwhile, try to avoid damaging the slot in the head of the screw.
Soak -- heat -- loosen -- remove -- and don't worry about the tuning adjustment aspects.
If existing number of turns out from lightly seated proves indeterminable, could use reassembly setting position similar to the other carb. Or the default preliminary setting usually noted in the FSM.
In any event, the screw will need re-adjustment later when fine tuning the carbs, regardless of whether or not it was returned to the exact "frozen" position.
- bountyhunter
- Thank you received: 337
Best way is to cut down a screwdriver to fit. Find a screwdriver whose blade thickness matches the jet screw's gap PRECISELY and then grind it to the width to match the screw width.Patton wrote:
Typically, a screwdriver whose width fits the screw has too thin of a blade and using it ruins both the screwdriver and the brass screw.
NOTE: I would put some Kroil or similar on that screw and soak it overnight to try to loosen it up.
- jbeebe1
The first one i did, i couldn't tell how many turns out it was seated before i started messing with it, so on the 2nd carb I payed more attention and it was almost exactly 2 full turns from bottom. I returned them both to that position once i cleaned them out.
Also, the bottom of the screw at that tiny little tip (that i felt like i was going to break off with every touch)...should there be a hole in it? mine is solid with no hole, and i'm just wondering how this screw actually adjusts the a/f ratio (mechanically speaking).
79 Honda CB650
81 Honda CX500
- bountyhunter
No holes in the screw. It meters airflow by moving in and out of the seat.jbeebe1 wrote: Well i managed to break the pilot screws loose. With about a day of soaking in PB Blaster and me buying a cheapo driver from H.F. that fit perfectly, she broke free without too much incident. I could have torched it too, but wanted to do that as a last resort.
jbeebe1 wrote: ...wondering how this screw actually adjusts the a/f ratio (mechanically speaking).
The carb pilot circuit includes a passageway whereby the air/fuel mixture passes through an orifice into the carb bore, from where it is sucked into the combustion chamber.
The pilot screw regulates the volume of mixture allowed to pass through the orifice.
- jbeebe1
79 Honda CB650
81 Honda CX500
