Overhauled Carbs VM28SC - Z1A issues
- picard
picard wrote:
Patton wrote: Are all 4 choke plungers fully closed -- as they are supposed to be -- when the choke lever is OFF?
Yeppers. all chokes work as they should. ~
Reason I (think I) do know this is when I first started the bike it needed the choke (it's in the 50s here right now) and they worked as they should.
- mtbspeedfreak
- Thank you received: 36
I can definitively say the chokes work perfectly.
picard wrote:
mtbspeedfreak wrote: Just thought of this, what are your intake boots like? Any chance they'd be cracked or the plates are warped?
Plates?
The intake boots (if you mean what's often referred to as "the carb holders", i.e between the carbs and the cylinders) are new-ish and the bike passed a WD40 leak test with the old carbs (and they pulled about 7-8 psi vacuum as they should) but I can take the intake boots off and inspect them.
Yes, carb holders (I call them intake boots usually, for some reason...). There's a steel plate which is how they can be screwed into the head. The plates can be bent by over-tightening the mounting bolts, which could potentially create a vacuum leak. But if they're relatively new (as in not the original ones that are 40 years old), chances are they're fine.
2000 ZRX 1100
1976 KZ 900- Daily Driver
- mtbspeedfreak
Would you need a smaller pilot jet for your altitude? Even at 1/2 throttle, the pilot jet is still a big part of the mixture.
But I feel like the jets aren't a problem, the fuel level is. If they've passed the clear tube test, and they aren't overflowing, what would that be? Would the float valve and seat be the issue?
Trying to think of all possible situations, you don't have any kind of fuel pump do you? Just the gravity-fed (manual) stock petcock?
2000 ZRX 1100
- Del_Herring
- Thank you received: 29
I would think if the float valve or seat was an issue, that it would show up in the clear tube test. i.e. if they aren't seating right, it'll overflow, even if just a little, so you'll show too high on clear tube. And if they're somehow getting stuck, your bowl wouldn't fill right, which should also show in clear tube, but as a low level.
1983 KZ750-N2 Spectre
- Thank you received: 2098
When cold, application of choke may seem normal while the plungers are pulled up, allowing the additional fuel mixture into the carb bore.
The issue presents as the engine warms and then requires zero mixture from the enrichener circuit.
Failure of choke plungers to completely close the enrichener circuit isn't so common as other prospective faults, but in this case where so many other possibilities have already been ruled out, it may be at least worth checking.
If not already done, would also assure that nothing stored under the seat is obstructing the air filter grill, such as a shop rag, riding gloves, etc.
- Motor Head
- Thank you received: 391
You Will have to adjust the Air Screws, for Idle and Off Choke warm up, low speed running. A small change must be tried and test ridden. Moving the Needles so they lower 1 notch might be a good Idea up in altitude, but only testing will determine that. I used to live up in Colo Springs, and would only change the Idle Mix for different seasons. No other Jets winter or summer, even with altitude changes, but they are CV carbs..
- BlackZ1R
- Kawasaki in my blood
- Thank you received: 47
I would start by setting them for your altitude and then go from there. Sounds like they are a bit on the rich side and could use lower fuel levels. Patton may be on to something with the choke circuits.
Also, don't take this the wrong way. I am not a big fan of media blasting carb bodies. It is very hard to get all the blasting media from all the tiny circuits and threads in a motorcycle carb body.
Soda blasting is the only way to blast a carb and assure all the media is cleaned out.
I bought a spare set of carbs off of eBay that I didn't realize had been bead blasted until I got them here. Even after the owner had cleaned them and run them on his bike for several thousand miles, I am still getting blasting media out of the pilot circuits. These have never been on my bike, and won't go on my bike until I'm satisfied all the blasting media is completely purged from them. :pinch:
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- Motor Head
BlackZ1R wrote: CV carbs are completely different at altitude changes, they actually work very well.
Never Media Blast those poor little drillings. :ohmy:
- mtbspeedfreak
Turns out, I had made a mistake, the main jets were not the stock 112.5 as I had remembered and insisted that they were, they were 122.5. I've since ordered brand new 110 mains and 15 pilots in a way to make good on my oversight.
Any other comments or criticism?
2000 ZRX 1100
- BlackZ1R
mtbspeedfreak wrote: Yes the carbs were bead blasted. I did so myself. I also took an extra month to ensure that all the blasting media was completely removed from the carburetor passageways and threads because I am well aware of the danger of not doing so. I spent two months rebuilding these, double and triple checking everything and in doing so, realized that I have a bad case of OCD. They are cherry.
Uppity, uppity.. No criticism meant mtb. I am just not a fan of media blasting and was offering my experiences with blasted carbs. Pilot circuits catch it worst.
I think we all have a bit of OCD in our old(er) age, and if y'all are like me it can get you into more trouble at times it seems :pinch: :laugh:
Kawasaki
- picard
Last thing I wanted is start a discussion about cleaning methods (though I do find it interesting ) I have the carbs apart quite far and they do look very clean and nice inside.
- mtbspeedfreak
picard wrote: Last thing I wanted is start a discussion about cleaning methods (though I do find it interesting ) I have the carbs apart quite far and they do look very clean and nice inside.
Haha yeah I was hoping that topic would be avoided. Not only did I clean out the jets with water and air, several times after media blasting, I also wiped down the insides with a clean rag with a few drops of 3-in-1 oil to make sure any residue was wiped off.
I only blasted the carburetor bodies with the top cap and float bowl assembled. I did not blast the interior of the float bowl area, nor try to blast inside any fuel or air passages.
2000 ZRX 1100
