KZ400 Single Carb - NEED HELP! (PWK35)
26 Sep 2012 22:47 #551076 by treitz
Okay... I am baffled. I was using the CV style carbs, so this flat slide is new to me. My petcock is not vacuum operation, and either is the carb.
When I turn the petcock ON, the fuel line fills, and the bike runs fine. However once the carb uses up whatever is in the float bowls, and whatever is in the fuel line, fuel STOPS flowing from the petcock. So the bike essentially run out of gas. If I stop, turn the petcock off, and then back on, it starts flowing again and does the same thing over again.
WHY does the fuel stop flowing? Is this a back pressure thing? How do I fix it!?
1979 KZ400 - 2-1 Manifold - Mikuni VM34
  • Motor Head
26 Sep 2012 22:52 #551078 by Motor Head
Replied by Motor Head on topic KZ400 Single Carb - NEED HELP! (PWK35)
Try it with the fuel cap open, just into a container, check the flow. It may have a blocked tank vent which is in the cap.
26 Sep 2012 22:59 #551080 by treitz
Replied by treitz on topic KZ400 Single Carb - NEED HELP! (PWK35)
That was suggested before... Would that make sense though considering when I turn the fuel off and then on it flows freely again?
26 Sep 2012 23:09 #551082 by treitz
Plus, if its not connected to the carb it flows freely. Gas cap on or off.
27 Sep 2012 00:37 - 27 Sep 2012 13:14 #551109 by loudhvx
Replied by loudhvx on topic KZ400 Single Carb - NEED HELP! (PWK35)
An in-line, paper, fuel filter can cause weird symptoms like that. If you have one, you may want to get a scintered filter or a metal screen filter.
Last edit: 27 Sep 2012 13:14 by loudhvx.
  • lushbaugh
  • everybodys a pro......
27 Sep 2012 01:44 #551117 by lushbaugh
Replied by lushbaugh on topic KZ400 Single Carb - NEED HELP! (PWK35)
your petcock has to nipples, one for output and one for vaccum signal to open the diaphram to flow fuel. make sure the vac nipple is getting good vac. you can suck on it and watch it run if you need to. next if thats all proper check that the floats still dropping to allow the needle seat to open. from what it sounds your getting the prime amount from turning the petcock lever and thats it. your vac signal has to be hooked up and if not you need a gravity petcock. good luck ill keep checking back to try and help
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
28 Sep 2012 01:31 #551309 by treitz
No vacuum. Aftermarket petcock. No flow when connected to carb.
  • Motor Head
28 Sep 2012 09:14 - 28 Sep 2012 09:15 #551333 by Motor Head
Here is a link to the Keihin PWK 35 parts breakdown. www.jetsrus.com/carburetor/carb_keihin_P...oded_view_parts.html
Maybe open the drain screw, and watch the flow into a container. The hinge on the float may be sticking, or the float adjustment could be wrong. There is both a fuel height and a float drop adjustment. Basically the drop adjustment is so it can open the valve fully without the float contacting the bottom of the bowl. You can check the height with a clear piece of tubing held alongside the bowl. I don't see any inlet filter screen in the breakdown, but there could be one, or something else causing the restriction. With the bowl off you can operate the float with your finger and watch the flow.
Have you had the bowl off? Checked the fuel height? Or anything yet?
Last edit: 28 Sep 2012 09:15 by Motor Head.
28 Sep 2012 11:21 #551345 by Del_Herring
Replied by Del_Herring on topic KZ400 Single Carb - NEED HELP! (PWK35)
Maybe the float valve is just sticking for some reason? Try giving a hearty tap to the carb bowl with a screwdriver handle or something similar to see if that opens it back up when it gets stuck. If that works, I'd just give it a thorough cleaning and try again.
1983 KZ750-N2 Spectre
28 Sep 2012 11:45 #551351 by treitz
I've opened up the carb and everything appears to be operating just fine. However I am not sure what the float height is suppose to be. Have had a hard time finding that info online.
  • Motor Head
28 Sep 2012 12:36 #551359 by Motor Head
About 3mm below the gasket surface, fuel level checked with a clear piece of tubing attached to the drain, drain open petcock on, route the tube up along the side of the carb for a sight gauge.
  • Motor Head
30 Sep 2012 23:12 #551778 by Motor Head
How about the carb bowl vent? The bowl must have a clear vent to allow fuel in.
