- Thank you received: 20
KZ1000st Quick Carb Q
- DesertKZ
26 Sep 2012 17:50 - 26 Sep 2012 18:50 #551031
by DesertKZ
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
KZ1000st Quick Carb Q was created by DesertKZ
'79KZ1000st with the Mikuni VM26's
Bike was running pretty good, a tad lean a few weeks ago and on the advice of my mechanic, he suggested I bump up to 115 main's from the stock 110's due to pods/cored exhaust.
Since then, bike's been running really rich, bogs, you can smell fuel in the exhaust, plugs are dirty, etc.
I checked the coils/wires all ohm's are within spec. Spark looks healthy blue.
Petcock (vacuum) is rebuilt, works perfect, float levels are within spec. No more air leaks in the intake. Could moving to these 115's have affected how it's running? I thought those were more for midrange?
BTW I rebuilt the carbs and valves are within spec as well. Confusing.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
Last edit: 26 Sep 2012 18:50 by DesertKZ.
- Nebr_Rex
- Thank you received: 300
26 Sep 2012 22:54 #551079
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic KZ1000st Quick Carb Q
Vm28s with 110s are stock for a '79st.
What is a tad lean?
What is cored?
What pilot jets?needle and position?
What is a tad lean?
What is cored?
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- DesertKZ
26 Sep 2012 23:15 #551085
by DesertKZ
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
Replied by DesertKZ on topic KZ1000st Quick Carb Q
Ok plugs were more white than tan, stock pilots and needle settings. Suggestions?
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
- Tomolu5
- Thank you received: 45
26 Sep 2012 23:20 #551087
by Tomolu5
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
Replied by Tomolu5 on topic KZ1000st Quick Carb Q
Preface: I suck at carbs
That said, I would try going back to 110s, and raising the needle one clip.
Good luck
P.S. if the only change was the main jets, and it went down hill, probly not a good change.
Good luck
Mine:
- Chaotic Reason
- Thank you received: 15
26 Sep 2012 23:27 #551088
by Chaotic Reason
Michael
1980 KZ1000 shaft drive
Replied by Chaotic Reason on topic KZ1000st Quick Carb Q
Are you leaving it choked? And have you vacuum synced them after you rebuilt them?
Michael
- mark1122
- Keep twisting it
- Thank you received: 109
26 Sep 2012 23:34 #551091
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic KZ1000st Quick Carb Q
main jets affect the running at 3/4 to full throttle. 1/4 to 3/4 throttle is affected by the needle clip position. the fuel air screws affect the o to 1/4 throttle position.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- DesertKZ
26 Sep 2012 23:36 #551092
by DesertKZ
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
Bike starts on no choke, won't idle now.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
- Chaotic Reason
26 Sep 2012 23:39 #551093
by Chaotic Reason
Michael
I have an 80st, and on my carbs, VM28 pumpers, the needles only have 1 position. You can't adjust them. I don't know what they are like for carbs in question though.
Michael
- DesertKZ
27 Sep 2012 00:02 - 27 Sep 2012 11:10 #551098
by DesertKZ
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
I heard that before and it was suggested maybe the PO did a needle swap. From what I recall they were all in the middle notch. Thanks for everyone's suggestions BTW.
Cored exhaust - I took 12" out of the middle, removing the dented parts/acid damaged part. Still have the OEM plug on the end.
Not vacuum synced yet, only bench synced, waiting to get it running so I can drive it over to the shop for the vacuum sync (don't own the tool)
Bike was a basketcase and never came with an airbox, hence why I'm running pods.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
Last edit: 27 Sep 2012 11:10 by DesertKZ.
- DesertKZ
27 Sep 2012 16:23 #551207
by DesertKZ
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
Been thinking maybe my air screws need to be turned in a tad, going to try that after work today.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
- Chaotic Reason
27 Sep 2012 18:47 #551235
by Chaotic Reason
Michael
For you to be able to start it up with no choke suggests to me that you have an air restriction. And then for it to not idle suggests that it might be starving for air. Are the pods new? You might be onto something with the air mixture screws, but I'd suggest backing them out as opposed to turning them in. With how rich it sounds like its running, that'd be my bet.
Michael
- Kz1k420
28 Sep 2012 08:19 #551330
by Kz1k420
1980 KZ1000 A4
Replied by Kz1k420 on topic KZ1000st Quick Carb Q
I set my mix screw at 1 and a half turns ou from lightly seated have to do some final adjustments but she pulls like a bitch now and she only has a bench sync
1980 KZ1000 A4
