KZ1000 LTD carby question
- PRM068
26 Sep 2012 07:12 #550941
by PRM068
1982 KZ1000 LTD
KZ1000 LTD carby question was created by PRM068
G'day guys,
long question, short......regarding a Mikuni carb on a 1982 KZ1000 LTD.....would a faulty "o" ring on a carby float valve (where the needle goes), cause fuel to flood the cylinder ?
Been thinking a problem with my bike has been too much fuel in the carb, maybe because of float issues. The No.2 cylinder is always wet and eventually the plug can't handle it anymore and the cylinder may as well be dead. Still goes good though (the bike in general).
I did a glass tube test - seems good. Pulled the carbs apart, floats "float".....pulled the needle and seat out...."o" ring looks stuffed. It broke actually. Could this cause fuel to run past and flood the cylinder ?
Any help appreciated.
Peter.
Peter.
1982 KZ1000 LTD
- Motor Head
- Thank you received: 391
26 Sep 2012 09:07 #550957
by Motor Head
Replied by Motor Head on topic KZ1000 LTD carby question
Yes. Those O-Rings need to seal, or fuel can enter the carb without being controlled by the float valve. Change those out, and make sure the screen above them is clean.
- PRM068
26 Sep 2012 09:20 #550959
by PRM068
1982 KZ1000 LTD
Replied by PRM068 on topic KZ1000 LTD carby question
Thanks mate.
Going to try and source some o rings locally tomorrow to get by, as ones from the states will take over a week to get here. I really hope this was the problem all along.
Peter
Peter
1982 KZ1000 LTD
- Motor Head
26 Sep 2012 09:33 #550962
by Motor Head
You might just get rebuild kits for the carbs. About $25 USD ea + shipping to you. They will have new flat valves as well as the o-rings, plus the gaskets, o-ring for the mixture screws, etc.
The manual link in my signature will have your bike/ carbs.
- lushbaugh
- everybodys a pro......
- Thank you received: 35
26 Sep 2012 20:43 #551062
by lushbaugh
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
Replied by lushbaugh on topic KZ1000 LTD carby question
while your in there do your acc. pump and sensor diaphram. if you havent yet youll need too
- Motor Head
26 Sep 2012 22:24 #551075
by Motor Head
Sensor diaphragm? You mean the Slide Valve Diaphragm? Always check them when working on the CV style carb.
No Accel pumps on those, they are BS34 CV Mikuni's.lushbaugh wrote: while your in there do your acc. pump and sensor diaphram. if you havent yet youll need too
