- Thank you received: 2
Anyone use twinmax for carb sync on a KZ?
- Bunty27
26 Sep 2012 23:05 #551081
by Bunty27
1982 KZ550 LTD
Replied by Bunty27 on topic Anyone use twinmax for carb sync on a KZ?
I just found a motion pro mercury based carb sync tool for half the price of a regular one on my local craigslist and just got it this evening. So I guess I'm good for now.
But do keep the discussion going on a good 4 cylinder home-made solution with no liquids.
1982 KZ550 LTD
- Bunty27
26 Sep 2012 23:10 #551083
by Bunty27
1982 KZ550 LTD
And Del_Herring, the cm Hg unit reference here comes from the Kawasaki KZ550 manual (available on a link in Lou's signature), Page 22. It says in the fine synchronization or carbs section:
"Normal vacuum gauge reading is 19~24 cm Hg and the difference between any two cylinder should be less than 2 cm Hg."
1982 KZ550 LTD
- Tomolu5
- Thank you received: 45
26 Sep 2012 23:15 #551084
by Tomolu5
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
Replied by Tomolu5 on topic Anyone use twinmax for carb sync on a KZ?
Read some of the reviews on that thing, I have one too, just seems as though some precautions should be taken. Seems a proper seal when not in use is in order.
Also, I was grilling the guy(jeff I think) at the z1enterprises site at mid ohio, he said that it works...but you have to be patient/follow directions to a tee. Apparently bubbles are a problem.
Don't worry, it may take me a few months to gather the parts, but now there's a hair up my ass, and its an easy build, this will be tried:p
Mine:
- loudhvx
- Thank you received: 1616
27 Sep 2012 00:34 #551106
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Anyone use twinmax for carb sync on a KZ?
The bubbles are not a problem as long as the mercury level is high enough in the reservoir. In that case, a simple syringe can pull the bubbles out easily.
1981 KZ550 D1 gpz.
Other links.
- Bunty27
27 Sep 2012 12:23 #551156
by Bunty27
1982 KZ550 LTD
I'm hoping to give it a try this weekend and I'll let you know how well this tool works. I'm keeping my finger's crossed.
1982 KZ550 LTD
- loudhvx
27 Sep 2012 12:29 #551158
by loudhvx
1981 KZ550 D1 gpz.
Other links.
1981 KZ550 D1 gpz.
Other links.
The following user(s) said Thank You: Bunty27
