only likes PRI
- brentsspectre
21 Sep 2012 15:53 #550120
by brentsspectre
only likes PRI was created by brentsspectre
Got the gas to stop leaking, got the tubes all ran, and got to ride my bike, FINALLY! But I noticed that if I run the bike sith petcock set to ON, it'll "run out of gas" soon. If I drive around with the petcock on PRI, it runs fine. I do have an in-line filter that lays parallel to the ground on top of the engine, no room to have it vertical. Any ideas on why the gas flow is slow eevn on PRI, and why it'll die after driving with petcock set to ON?? Bad diaphram perhaps?
Its a KZ750N
If I need a rebuild kit, got any website suggestions?
Its a KZ750N
- Del_Herring
- Thank you received: 29
21 Sep 2012 16:00 #550124
by Del_Herring
1983 KZ750-N2 Spectre
Replied by Del_Herring on topic only likes PRI
Did you remember to hook up the vacuum line from a carb to the petcock? Otherwise, yea, that's a petcock diaphragm. If it's not leaking, I wouldn't think you even need a full rebuild. Z1 Enterprises should have you covered on that part, easy repair.
- Del_Herring
21 Sep 2012 16:01 #550126
by Del_Herring
Incidentally, worth considering if this might have any effect on the 4k problem from your other post.
- Thank you received: 1656
21 Sep 2012 18:08 - 23 Jan 2013 00:19 #550151
by martin_csr
Last edit: 23 Jan 2013 00:19 by martin_csr.
- brentsspectre
21 Sep 2012 18:57 #550163
by brentsspectre
Replied by brentsspectre on topic only likes PRI
There was a very small amount of gas on the outside of the petcock, not dripping, just moist. I think I'll try to go to Z1 for a rebuild kit. I'll also try to ride it with gas cap open.
Im glad I found this site, thanks for helping a newbie!!!!
