- Thank you received: 2
Bad auto petcock maybe?
- Bunty27
And can I use this petcock switch without connecting the vacuum hose? In that case, I'm guessing I'll only be using the PRIME position for feeding fuel to the carbs and the ON/RES positions will just be OFF. Will that work or do I have to repair the petcock or replace it with a non-vacuum petcock?
Any suggestions to what to look for and how to fix the leak in the ON/RES positions will be much appreciated.
1982 KZ550 LTD
- Motor Head
- Thank you received: 391
- Thank you received: 1656
- Bunty27
1982 KZ550 LTD
- Bunty27
1982 KZ550 LTD
- Motor Head
As far as a new Petcock, call Z1 and see what they have that fits. As I don't see anything on their website for the 550. Also at Pingel I don't see a 550 listing. But the guy's at Z1 will know.
- Bunty27
www.z1enterprises.com/ItemDetails.aspx?i...uum)+&item=KL18-2698
1982 KZ550 LTD
- Thank you received: 2098
Bunty27 wrote: Thanks for all your input. And it was another newbie error. I kept looking at the diagphram but when I opened the actual switch side, noticed that the valve gasket (the round rubber thingy with holes) was pretty messed up. I'm just going to get a rebuild kit from Z1 and install it. Looks like this should work:
www.z1enterprises.com/ItemDetails.aspx?i...m%29+&item=KL18-2698
- boatdrinks
- Thank you received: 54
Charles
Madison, AL
1978 KZ650 B2A, Luminous Dark Blue
- Bunty27
1982 KZ550 LTD
