Bad auto petcock maybe?
20 Sep 2012 23:46 #549993 by Bunty27
Bad auto petcock maybe? was created by Bunty27
The automatic petcock valve on my KZ550 LTD 1982(C3) seems to be letting fuel flow even in the ON position while the bike was parked in the garage. I just filled the gas tank to full for the first time this morning an did not notice any leaks then but wife found the leak at the inline fuel filter when she got home later in the evening. It was dripping pretty bad when I finally got home though my wife had managed to slow the leak by twisting the fuel tube. Now it doesn't look like the petcock itself is leaking but for some reason, the ON position didn't seem to turn off the fuel flowing in from the tank. It was the same story in the RESERVE position too. Am I looking at a bad petcock is something wrong with the vacuum system?:-O
And can I use this petcock switch without connecting the vacuum hose? In that case, I'm guessing I'll only be using the PRIME position for feeding fuel to the carbs and the ON/RES positions will just be OFF. Will that work or do I have to repair the petcock or replace it with a non-vacuum petcock?
Any suggestions to what to look for and how to fix the leak in the ON/RES positions will be much appreciated.
1982 KZ550 LTD
  • Motor Head
21 Sep 2012 00:03 #549998 by Motor Head
Replied by Motor Head on topic Bad auto petcock maybe?
z1enterprises will have a rebuild kit for your stock Vacuum Petcock, also a replace manual one that may require an adapter. There is a spring and an O-ring on the one side of the diaphragm that can fail. Not difficult or expensive to repair.
21 Sep 2012 09:39 - 23 Jan 2013 00:20 #550044 by martin_csr
Replied by martin_csr on topic Bad auto petcock maybe?
You can either get a complete petcock rebuild kit or just a diaphragm kit.
Last edit: 23 Jan 2013 00:20 by martin_csr.
21 Sep 2012 10:18 #550049 by Bunty27
Replied by Bunty27 on topic Bad auto petcock maybe?
I opened up the petcock and the thing looks to be in a pretty good shape. The O ring was just fine and the diaphragm isn't bad either. I'm just not totally comfortable with the fact that there is really no true off switch and when the vacuum mechanism fails, It leaks like crazy. Can I just not hook up the vacuum tube and only use the PRI switch as ON and use the other two as OFF? Or replace the entire thing with a manual switch? And do I really need an adapter for a manual one?
1982 KZ550 LTD
21 Sep 2012 10:21 #550050 by Bunty27
Oh, and the spring is fine too. Everything looks new on the inside.
1982 KZ550 LTD
  • Motor Head
21 Sep 2012 10:23 - 21 Sep 2012 10:28 #550051 by Motor Head
If you want something cheap and easy, you could go this route: www.z1enterprises.com/ItemDetails.aspx?i...+Line&item=MP12-0035
As far as a new Petcock, call Z1 and see what they have that fits. As I don't see anything on their website for the 550. Also at Pingel I don't see a 550 listing. But the guy's at Z1 will know. ;)
Last edit: 21 Sep 2012 10:28 by Motor Head.
21 Sep 2012 10:28 - 23 Jan 2013 00:20 #550052 by martin_csr
Mine looked new too, but the diaphragm was bad.
21 Sep 2012 11:57 #550070 by Bunty27
Thanks for all your input. And it was another newbie error. I kept looking at the diagphram but when I opened the actual switch side, noticed that the valve gasket (the round rubber thingy with holes) was pretty messed up. I'm just going to get a rebuild kit from Z1 and install it. Looks like this should work:
www.z1enterprises.com/ItemDetails.aspx?i...uum)+&item=KL18-2698
1982 KZ550 LTD
21 Sep 2012 18:16 #550152 by martin_csr
I've had good luck w K&L parts. Their stuff is made in Japan.
21 Sep 2012 20:58 #550188 by Patton
Replied by Patton on topic Bad auto petcock maybe?
Bunty27 wrote: Thanks for all your input. And it was another newbie error. I kept looking at the diagphram but when I opened the actual switch side, noticed that the valve gasket (the round rubber thingy with holes) was pretty messed up. I'm just going to get a rebuild kit from Z1 and install it. Looks like this should work:
www.z1enterprises.com/ItemDetails.aspx?i...m%29+&item=KL18-2698
Good Fortune! :)
The following user(s) said Thank You: Bunty27
22 Sep 2012 00:46 #550215 by boatdrinks
Replied by boatdrinks on topic Bad auto petcock maybe?
I repaired mine with genuine Kawasaki parts. No problem since. I'll see if I can find the parts numbers that I purchased.
Charles
Madison, AL
1978 KZ650 B2A, Luminous Dark Blue
26 Sep 2012 12:41 #550994 by Bunty27
I got the petcock rebuild kit from Z1 and was able to install it without any issues. I'll test it over this weekend and I'm sure everything will work fine now. Thanks much to everyone who pointed me in the right direction.
1982 KZ550 LTD
