New to forum
- kzcafer
20 Sep 2012 06:54 #549820
by kzcafer
New to forum was created by kzcafer
Just purchased a 1981 kz1100 shaft drive.. my questions are as followed.. i was thinking of putting open pod filters on. i have cut the stock exhaust and pulled the guts out of the cans.. do i need to rejet to have the bike run at its best... i have the stock 120 jets in but i have 130s on hand..also i heard that i can take the hose that comes from the valve covers and connect them when i put the air pods on... thanks in advance
- Topper
- Thank you received: 133
20 Sep 2012 07:55 #549830
by Topper
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
Replied by Topper on topic New to forum
Welcome to the forum!
I think you'd be looking at a re-jet if you did either of the mods you're describing (pods & removing baffles) Since you're doing both I'm thinking yes you're going to need to re-jet.
1979 KZ750 Twin
- Kz1k420
20 Sep 2012 11:47 #549874
by Kz1k420
1980 KZ1000 A4
Replied by Kz1k420 on topic New to forum
Fairly new my self have an 1980 kz1k a4 I have open pods on mine with the stock 2 to 1 pipes on it and Ive been playing with different jets sizes as well stock on mine are a 107.5 with open pods I have 110s in ATM bummed my 112.5 didn't come in yet cause she needs those in it... When I bought the bike and opened the carbs I found 127.5 way to big fOr just open pods and stock Exahust... Found outhe stock jets were a 107.5 by searching the bike on performance sports plus .com great place lists every little piece for the carbs if they can be replaced or not and the option of ordering parts as well
1980 KZ1000 A4
- trianglelaguna
- Thank you received: 235
20 Sep 2012 12:41 #549885
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic New to forum
welcome
yes you can cap the breather covers off...or connect em
1976 KZ900
2003 ZX12R
2007 FZ1000
- Kz1k420
20 Sep 2012 14:40 #549898
by Kz1k420
1980 KZ1000 A4
If I'm right the breather that connects to the valve covers is the vacuum breather that connects to te carb seats I recommend replacing the hoses and citing the long breather tube that ran to the air box and put a small air pod in the house ad have it sit just under the tank I'll post a pic later when I get off work of what I my self have done to mine
1980 KZ1000 A4
- kzcafer
20 Sep 2012 17:49 #549931
by kzcafer
Replied by kzcafer on topic New to forum
So I can bring the hose that goes from the valve covers to the plug in the trans.. also would it be better to leave stock air box on with the gutted exhaust and 130 jets..
- Kz1k420
21 Sep 2012 12:52 #550080
by Kz1k420
1980 KZ1000 A4
If u are running a four to 1 Exahust I'd do the open pods and gut the air box
1980 KZ1000 A4
- Del_Herring
- Thank you received: 29
21 Sep 2012 13:05 #550083
by Del_Herring
1983 KZ750-N2 Spectre
Replied by Del_Herring on topic New to forum
Think twice before moving to Pods. Trying to get carbs dialed in after moving to pods is probably the single most common thing that sends people to the looney bin here. There are certainly plenty of guys who get them working fine, but there's at least as many who think they've found an easy upgrade and spend the next 5 years wondering why their bike doesn't run right.
- Del_Herring
21 Sep 2012 13:06 #550084
by Del_Herring
I'd like to go pods eventually myself. But my recomendation would be to hold onto that airbox, you may end up wanting to put it back later.
- Kz1k420
21 Sep 2012 13:44 #550092
by Kz1k420
1980 KZ1000 A4
U make a valid point I wish when I bought my bike it has the air box but sadly no had open pods on it... An u are right about going to the looney bin I'm fighting getting the right jet size with open pods and stock Exahust I feel I'm winning the battle cause e is running a lot better with the 110s I put in instead of the 127.5s that were in it when I bought the bike... Stock main jet size on mine is a 107.5
1980 KZ1000 A4
- kzcafer
21 Sep 2012 15:07 #550112
by kzcafer
well today i got to ride it for the first time.. i just went around the block a few times without any filters on and stock jetting... i did jump the jets to 130s now and i will try the pods and see what happens..i have to put a new head gasket and valve cover gasket on so now i just sit and wait for parts... thanks guys
