Kz 750 e2 fuel coming out of overflow pipe when engine shuts off
- Mirbooya
I think that one of the carbies floats are too high. Any ideas? It has happened pretty suddenly.
1981 Z750 L1
- Mirbooya
1981 Z750 L1
- Thank you received: 2098
Mirbooya wrote: ...when I shut the machine off to check it the there was fuel around the center stand. I turned the tank valve to prime and sure enough more fuel came out.
If fuel is escaping from the overflow circuit, it's likely being caused by a dirty float valve, and not from some sudden inexplicable change in float height.
One very remote possibility is that the float happened to spring a leak out of the blue, which is far more unlikely than a speck of crud in the float valve.
If not already done, an aftermarket in-line fuel filter should be installed.
- Mirbooya
I have checked further and the fuel is only leaking from the number 4 carburetor. It is leaking from the drain hose on the float bowl. It is strange, but when you switch the fuel to prime the fuel is just pouring out like the drain screw is loose. I've checked the drain screw and it is tight. Tomorrow I'll check the float height. See picture attached.
Attachment ImageUploadedByTapatalk1347278932.156892.jpg not found
1981 Z750 L1
- Mirbooya
For the float needle seat and valve, is it better to get oe or the ones on z1 enterprises ok? Big price difference. But I have heard that only oe is good when it comes to carbs.
1981 Z750 L1
Mirbooya wrote: O.k just checked float height with clear tube on the number 4 carb only. It's way off. I could see fuel leaking from the carb to engine intake manifold, so I think I should change the oil as well.
Petcock in PRIME position allows gasoline to flow regardless of whether the engine is or isn't running.
This free flowing gasoline is getting past the leaking float valve and into the float bowl, where it keeps rising until it supposedly escapes via the overflow circuit, at which time the fuel level exceeds spec.
The clear tube test is accurate only when the fuel valve isn't leaking. Because if the fuel valve is leaking, the fuel keeps rising inside the bowl (unchecked by the fuel valve).
When the float valve is leaking, the clear tube test is meaningless, except to indicate that the fuel level is unstable and not being limited by the float valve when the float valve is supposed to closed.
Fuel rising on up past the overflow and into the carb throat indicates that the the overflow circuit is obstructed, or partially obstructed, or that the float valve is leaking so badly that the overflow circuit is overwhelmed by the volume of incoming fuel.
Would suggest cleaning both the float valve and the overflow circuit.
Would also assure that the petcock isn't flowing fuel in either the ON or RES position when the engine isn't running.
Unless the float needle and/or float needle seat is damaged or worn out, a good cleaning of both the needle tip and seat orifice often eliminates the float valve leak and restores the float valve to proper function, without needing any new parts.
Sometimes it helps to chuck a Q-tip in the drill and spin it inside the seat to clean the orifice, using carb cleaner on the Q-tip.
While the carb is overflowing, another trick is to rap smartly against the float bowl with a plastic hammer or screw driver handle, which may also be done with the engine running, which sometimes stops the leak.
Running some SeaFoam additive to the fuel may also help clean the float valve and eliminate the leak.
- Motor Head
- Thank you received: 391
You can drain each carb into a clear container looking for debris, to see whats got into them. You can replace that #4 float valve and reset fuel height there on the bike. But probably best to pull the rack and clean all 4 carbs out, along with the tank.
- Mirbooya
Hi Patton, the above advice did the trick and stopped the leak. Sharp tap from screw driver handle with carb overflowing into plastic bottle. It was good tip. Now I will ensure I fit an inline fuel filter ASAP.
1981 Z750 L1
- Mirbooya
1981 Z750 L1
