Plug reading photos UPDATED, clear, 3photos
- jsanch08
I updated these photos to show what I think is the annealing line, and, the creamic insulator,
more clearly
www.dpreview.com/galleries/1280783007/al...at-41miles/slideshow
If anyone has a few seconds to run through them an offer a perspective, that would be appreciated.
Also, I put the plug in new, ran it for 41 miles continuously, or about an hour and a half, about half that mileage at 5500 rpm, the rest stop and start and drive.
- 4TheKZ1000
- Visitor
- jsanch08
But, I learned all I know about plug reading on the internet.
- wireman
- Thank you received: 299
Black would be rich or ignition isnt doing its jo.
White would be lean
- Thank you received: 2098
jsanch08 wrote: I reset the float height on my KZ200....
Is fuel level within spec as evidenced by the clear tube test?
- jsanch08
The float height is a slightly strange story. I rode the bike from 1992-2001 and put 3000 miles on it without ever checking the float height. I stored the bike from 2001 to this summer, and, when I pulled it out of storage, it would not idle.
I cleaned the idle circuit with some 28 guage copper wire, and cleaned up the float bowl etc. The idle came back, but, the idle was not stable.
So, I took some 1/8 tubing and wrapped it with teflon tape and screwed it into the drain the carb bowl and measured the static height below the gasket surface. It was 11mm below that gasket. I checked the spec and it was 5mm. Note, I did not tap the float bowl to see if that was a false reading, because, at that point I was still learning.
So, I pulled the float and bent the tang a few times until distance from the gasket was 6mm. But, after that the bike ran very rich, and, in fact, for whatever reason, sometimes the float level would exceed the height of the gasket and go to the overflow. After trying to get the float level to stabilize, and failing, I reset the float level to 8mm below the gasket surface (spec is 5mm).
Bike runs good, but, the ceramic is white, not tan.
I will have to learn more about tan vs white.
- jsanch08
But, it shows not sign of blistering, and, there is no sign of metal particles on it.
- OldSchoolZ
- Thank you received: 33
The outer ring(lowspeed) is speckled, showing that your top end is lean enough to start cleaning that area, the redish color is gas additives, your top end is lean. An overall light brown to brown is a good mixture.
Keep in mind any one area thats way rich could blacken the whole plug.
Thats just my years of tuning based in my opinion.
When I check top end only, I use a clean or blasted plug, then get at topend for a long ways and pull clutch and kill ignition on rt handlebar. Then stop and check plug right there.
Remember, don't work on your bike so much you never ride it.
- Kraz1
> NGK Info
- wireman
I guess I need new glasses,looks tan to me anyway.jsanch08 wrote: The ceramic is white. Not tan.
- 4TheKZ1000
- Visitor
+1 here
- Tomolu5
- Thank you received: 45
That's cause you always got those sunglasses on
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
