Vacuum petcock / poor performance
- cbewley
05 Sep 2012 22:02 #546925
by cbewley
'81 kz750H with '77 650B motor
Vacuum petcock / poor performance was created by cbewley
Took my 740/4 out for first time in a few days today. Ran fine last week. Within 1/2 mile from home, thing starts bucking and sputtering like she's running out of gas or something (had 1/2tank+). It subsided, I ran my errands, cruised about 7 more miles and until it got really bad, then limped home.
Noticed a nut fell off a bolt to hold a coil on, so I removed the tank and it starts pissing gas all over the place. Reattached the coil, and tightened the others, and drained gas into an can. Pretty much goes without asking that I need to rebuild or clean the petcock, but was this the cause of the bucking/sputtering from flooding the carbs or something?
First start up was normal, and it idled fine. Just crazy lurching through the power band.
I was also thinking a coil may be going bad. I've dealt with that already and that's more of a severe power loss and no idle compared to the iron horse trying to throw me off.
- MFolks
- Thank you received: 540
05 Sep 2012 22:38 #546932
by MFolks
Replied by MFolks on topic Vacuum petcock / poor performance
First, remove the screws for the gas cap. I think a vent hole may be plugged, causing the lurching. Do you have the Kawasaki supplied electronic ignition? If so, a pick up coil may be heat sensitive.Read this:
Ohm Checking Pickup(Pulsing) Coils
The pickup(Pulsing) coils on the Kawasaki’s with the factory supplied electronic ignition can sometimes fail or become intermittent due to heat and vibration.
1.Trace back from where the pick up coils are mounted,(BEHIND A RIGHT SIDE, CD SIZED ENGINE COVER) locate and disconnect a small 4 pin connector. Using a multi-meter set on OHMS and range of 2K, check between the BLUE and BLACK wires(#1 and #4 sparkplug wires) for between 360- 540 OHMS.
2.For #2 and #3 sparkplugs the wire colors will be YELLOW and RED, again 360-540 OHMS. The 550’s,650’s & 750’s may be backwards to the Z1’s,Kz900’s,Kz1000’s & Kz1100’s.
3.If the pickup coils are suspect of failing due to heat, they can be stressed using a hair dryer without the need of the engine running.
4.A replacement set of pickup coils might be obtained from a dealer who serviced the police Kawasaki’s.
5. If replacement pickup coils are not available, your next choice would be to order a Dyna “S” electronic ignition system from www.z1enterprises.com It replaces the IC igniter with a smaller module located where the mechanical ignition advancer was mounted.
6. Checking with Kawasaki.com website has determined that the Pick up(pulsing) coils are available . The pulsing coil # is 59026-1133 and replaces the older # 1002, 1012 which were used from the MKII motors until the 2005 P24.
7.Check the small 4 pin connector that the pickup coils connect to for corrosion/loose pins too.
8. The mechanical ignition advancer needs periodic service too, it's in the area of the pickup coils, mounted on the end of the crankshaft. Some light lubrication on the weight pivots and the moving shaft are about all it needs. A dab of Moly grease or 3-in-one oil will work for this.
Are your ignition coils as old as the bike? They need replacing too, as the coils can break down when hot.
Ignition Coils And Sparkplug Wire Choices
What came with the bike, were ignition coils that even when new were marginal, add years of cooking under the tank in the stop and go traffic, and the coils will probably fail when hot.
Replacement coils can be bought at www.z1enterprises.com I believe “Emgo” is the brand. They also carry the popular Dyna 2.2 and 3 ohm coils, along with replacement sparkplug wires.
Now, you have a choice on sparkplug wires:
1.Copper plug wires with no supression caps (the best choice, but will produce audio noise on Radio’s and TV’s). Not only do the copper core wires deliver better spark, they will also deliver a much longer lifespan - carbon core wires are prone to erratic spark delivery and early breakdown, & short lifespan.
2.Copper plug wires with supression caps(a built in 5000 ohm resistor, that can sometimes fail, like what came with the bike).
3.Copper plug wires with no supression caps, but using resistor plugs(the “R” in the plug number, like B8RES).
4.Supression plug wires with no supression caps.
NEVER use resistor plugs combined with supression caps along with supression plug wires, as now there will be two (2) sources of resistance in the secondary windings of the ignition coils, greatly reducing the spark energy.
Another choice is the Accel 3 ohm coils, with a similar, primary(small wire)electrical connection, using ring terminals as the Dyna ignition coils do. Whatever brand of coil you go with, make sure the primary wires will clear the mounting hardware, as the spacers come awfully close, possibly blowing a fuse. Some riders have replaced the metal spacers with non conductive Nylon spacers, reducing the chance of an electrical problem.
7mm sparkplug wires will fit the stock ignition coils(if they have replaceable wires, indicated by screw off caps on the coils with ridges). The sparkplug wires fit into a port with a brass ”Stinger” that goes into the sparkplug wire or lead(the Brit’s. Canadians, and other countries call the sparkplug wires (“High Tension Leads”).
- cbewley
06 Sep 2012 01:43 #546965
by cbewley
Replied by cbewley on topic Vacuum petcock / poor performance
My ignition system is pretty much frankensteined together. Dyna S ignition that was pieced together from two half working systems. One 3-ohm Dyna coil and one 3-ohm Yamaha coil(the other Dyna was toast). It's been that way since 1 year ago when I was having all sorts of electrical gremlins, but it's run great since then.
I'll check into the gas cap screws and find my Dyna S printout from last year to check ignition pickups tomorrow.
- ironslave
- sup
- Thank you received: 2
06 Sep 2012 04:41 #546980
by ironslave
1981 KZ750 LTD
Replied by ironslave on topic Vacuum petcock / poor performance
My Vacuum valve was not closing well either. I took apart the diaphragm and stretched the spring out. It would open fine but was slow to return when it was removed and I sucked on it to test it. After I stretched the spring out it closed as fast as it opened.
If your floats are not working correctly or the float valve is worn it won't fully block off the fuel and it can overflow. you should check the overflows on the carbs to see if fuel is coming out of them. When the bike begins to misbehave just pull over and turn it off and yank the overflow tubes off the carbs and see if fuel comes out. My Overflows go to my air box and it sucks the fuel into the engine so it runs rich. My bike tends to idle high when it goes rich though, which I found odd because on my ATC's running rich causes them to bog down.
Also, I found that depending on which coil goes belly up it produces a different reaction, one set will not affect it much while the other will cause a huge loss in power. try swapping the coils and see what happens.
1981 KZ750 LTD
- Thank you received: 2829
06 Sep 2012 09:07 #546989
by 650ed
Replied by 650ed on topic Vacuum petcock / poor performance
If your coil was flopping around because a mounting bolt fell off it may have been intermittently shorting out against the frame or fuel tank. That could cause the erratic running you described. Ed
- cbewley
06 Sep 2012 16:08 #547076
by cbewley
Turns out I had a loose bullet connection. Thanks for the input, guys. Guess those two issues were unrelated.
And thanks ironslave, stretching the spring inside the fuel tap seemed to do the trick.
- MFolks
06 Sep 2012 16:16 #547078
by MFolks
With a bike that's running very erratic, it can be almost many things(sometimes at the same times).
- cbewley
16 Sep 2012 20:42 #549128
by cbewley
All that bucking from 15 days ago really shredded my rear sprocket. Nearly threw the chain this past Thursday. Lucky I was only 2 miles from home.
Attachment sprocket.jpg not found
- Thank you received: 1656
18 Sep 2012 10:41 - 23 Feb 2013 16:01 #549424
by martin_csr
Last edit: 23 Feb 2013 16:01 by martin_csr.
