- Thank you received: 34
how much vac to open fuel tap?
- P21
05 Sep 2012 13:08 - 05 Sep 2012 13:11 #546830
by P21
Kawasaki KZ 1000 Police (2002) P21
how much vac to open fuel tap? was created by P21
ok i what to drain gas tank on work table.
going to put fuel tap to (on) and then put tap to (res)and then with (mighty vac)pump open valve.
what i need to know is how many lbs 2-3 or just till gas runs out,my harley takes 6 lbs
what really am after is my reserve amount 1/2 gallon like manual says or 1 gallon like its seems to me when fill up only takes 2.5 gal or little more.
book says 4 gal tank total
i would like know for sure i travel alot and this a pain azz not really knowing.
thanks for help.......... PS aint no fun running out on reserve.
Last edit: 05 Sep 2012 13:11 by P21.
- Thank you received: 2237
05 Sep 2012 13:24 #546837
by TexasKZ
Replied by TexasKZ on topic how much vac to open fuel tap?
Interesting. I have no idea about the vacuum needed, but somehow -6psi seems like a lot.
Once you have the fuel level below the ON tube, you will not need the vacuum. You can turn the petcock to PRI and gravity will pull the fuel out. As you have surmised, the factory capacities are only approximate.
- P21
05 Sep 2012 13:44 #546840
by P21
Replied by P21 on topic how much vac to open fuel tap?
ok sorry its only 25 in Hg of vacuum on the harley i had to dig out my service manual
but thanks on the prime thing.
i just have little more gas to go then hit reserve. thats why i am using mighty vac thing to make it act as to run out in the (on) position
- loudhvx
- Thank you received: 1616
05 Sep 2012 14:37 #546847
by loudhvx
When running, a typical bike will have between 8 and 15 inches of mercury. The petcock seems to be able to open pretty far below that.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic how much vac to open fuel tap?
That can't be right. 25 inches of mercury is close to a perfect vacuum. 25 inches of mercury is also about -12 psi.P21 wrote: ok sorry its only 25 in Hg of vacuum on the harley i had to dig out my service manual
1981 KZ550 D1 gpz.
Other links.
- P21
05 Sep 2012 16:12 #546864
by P21
ok fellow riders the results are in! (up-date)
ok the reserve is 1 gallon geez :evil:
and it only took about 0.5 in Hg to open fuel tap
well now i know the rest of story i feel much better thanks for the help guys.
so in the end i would say she holds about 3.7 gallons sounds about right.
