vaccum lines
- brentsspectre
04 Sep 2012 12:51 #546591
by brentsspectre
vaccum lines was created by brentsspectre
I'm new to motorcycle ownership and have a question about my carbs and petcock. I have a 1982 KZ750N with Keihkin carbs. I believe I need to run lines from the black nozzles in between the carbs back to the petcock. The petcock is vaccum operated, I think, because it has two ports. Should the lines running from the black nozzles in between the carbs be joined by a T and ran to the petcock, or does 1 black nozzle get tied into something else, while 1 comes back to the petcock? When I got it started the RPM's were at 6K and wouldn't back down! I've checked the boots and they look ok, I'll try to clamp them better than the old springs that are on there now, and check them once I can get the RPMs down.
New to the site and have learned a lot already!!
Thanks in advance for helping a new guy out!!!
- Thank you received: 2098
04 Sep 2012 13:09 #546593
by Patton
Replied by Patton on topic vaccum lines
Hello, brentsspectre, and WELCOME to KZrider!
Here's some carb connection info:
Any still existing "clean- air" paraphernalia may be removed and shelved.
The following user(s) said Thank You: bl_francis
- brentsspectre
04 Sep 2012 13:22 #546596
by brentsspectre
Replied by brentsspectre on topic vaccum lines
So the nipples on carbs 1 and 4 are tied into a vacuum switch?? Can they be capped? Where might the switch be?
Thanks for the info!!
04 Sep 2012 13:33 - 04 Sep 2012 13:34 #546599
by Patton
Part # 6 is the "Vacuum Switch Valve."
Many bikes have already had the clean air stuff removed.
Be sure any unused vacuum nipple is capped/plugged (to prevent an air leak).
It's also important that the two nipples which vent the float bowls exit to open air.
This is usually accomplished by a hose attached to each vent nipple, which hoses exit to to open air underneath the bike, or sometimes exit to open air underneath the bike seat, or possibly exit into the air box.
Last edit: 04 Sep 2012 13:34 by Patton.
- Del_Herring
- Thank you received: 29
04 Sep 2012 13:49 #546603
by Del_Herring
1983 KZ750-N2 Spectre
Replied by Del_Herring on topic vaccum lines
The one and four vacuum ports go to the clean air stuff mentioned by patton. If you remove the clean air stuff (or if it's already gone), just cap those, so you'll have 3 capped ports, and the one still going up to the petcock vacuum.
