Just got my new 440
- duncan882
04 Sep 2012 10:08 #546551
by duncan882
Just got my new 440 was created by duncan882
I just recently purchased a kz440 ltd, I was tearing apart my carbs and i believe there is a piece broken on them. If you look at the picture at the part with the spring is missing something. If you could point me in the right direction on what to look for it would be greatly appreciated.
- Thank you received: 2098
04 Sep 2012 10:14 #546554
by Patton
Hello, Duncan882, and WELCOME to KZrider!
There's a link in my signature for help with navigating kawasaki.com to see the detailed parts diagrams, etc., which diagrams will include the carb return spring.
Replied by Patton on topic Just got my new 440
duncan882 wrote: I just recently purchased a kz440 ltd, I was tearing apart my carbs and i believe there is a piece broken on them. If you look at the picture at the part with the spring is missing something. If you could point me in the right direction on what to look for it would be greatly appreciated.
- Motor Head
- Thank you received: 391
04 Sep 2012 10:15 #546555
by Motor Head
Replied by Motor Head on topic Just got my new 440
Looks like a linkage piece to actuate the choke on the right carb. You can see in your picture one choke open,R, and one closed,L. You don't state the year and Model, which is needed to try and get the correct parts. But look at this parts diagram and see if it helps with seeing the broken or missing piece.
- Thank you received: 1656
04 Sep 2012 10:15 - 22 Jan 2013 21:23 #546556
by martin_csr
Replied by martin_csr on topic Just got my new 440
listing ended
Last edit: 22 Jan 2013 21:23 by martin_csr.
- duncan882
04 Sep 2012 10:42 #546565
by duncan882
Replied by duncan882 on topic Just got my new 440
That what i thought at first once i get home I will upload more pictures just to be sure. Thanks for your help.
