Hesitation at 4,000 rpms
- 1960vw
04 Sep 2012 01:38 #546522
by 1960vw
1982 kz305
Hesitation at 4,000 rpms was created by 1960vw
My '82 kz305 developed a hesitation at 4,000 rpms, like it bogs down or low on fuel, something like that. Runs up nice to then and over that it goes great. I took apart the carb cleaned everything out and made sure to blow compressed air from a can to make sure all ports and jets were clear.Diaphrams were solid and good. I thought for sure that would solve it. Replaced points and condensor, retimed, adjusted valves. No air leaks around boots that I could find. New spark plug caps as well as plugs. I tried to adjust float level and think I did it right using clear tubing. What am I missing?
1982 kz305
- DiamondSkyBlue1000
- Thank you received: 40
04 Sep 2012 02:43 #546526
by DiamondSkyBlue1000
Replied by DiamondSkyBlue1000 on topic Hesitation at 4,000 rpms
Petcock and filter clean?
Is it always at 4k in the same gear? That is, is it always at a certain throttle position or at 4k no matter what the throttle position is?
- Thank you received: 2098
04 Sep 2012 07:46 #546539
by Patton
Replied by Patton on topic Hesitation at 4,000 rpms
Perhaps igntion timing advancer is sticking.
Could verify advancer performance with a strobe type timing light, by watching the timing move quickly back and forth as rpm is varied by blipping the throttle.
Would in any event lube the weight arm pivot points on the advancer.
At the least, a drop of oil on each pivot point, which may be accessible through the timing inspection window.
Re-test with timing light.
If timing light shows erratic behavior of the advancer, would remove the advancer for inspection, cleaning, and lubing.
04 Sep 2012 07:51 #546540
by Patton
There is a specified protocol for timing where points are involved.
First -- dress and clean the contacts. May use a folded over strip of fine sandpaper pulled through the contacts.
Next -- set the gap. And re-clean the contacts.
Finally -- adjust the timing.
- 1960vw
05 Sep 2012 00:46 - 05 Sep 2012 00:47 #546746
by 1960vw
1982 kz305
Replied by 1960vw on topic Hesitation at 4,000 rpms
It does it in all gears at the same rpms regardless of throttle position, I will do the checks suggested, thanks !!1
1982 kz305
Last edit: 05 Sep 2012 00:47 by 1960vw.
