- Thank you received: 1
kz400 2 into 1 setup and keihin 35mm carb
- gumby prichard
03 Sep 2012 16:50 #546424
by gumby prichard
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
kz400 2 into 1 setup and keihin 35mm carb was created by gumby prichard
a while back when i first got my 78 kz400 b1 i got it running first on the 2 into 1 set up. it is copper and comes with rubber intake boot. i also have a keihin 35mm cr250 carb. i will sell full set up for $100 or $60 a piece. carb will just need the idle adjustment screw and spring. FYI i did get the bike running on this set up, but my friends father convinced me to run it stock, and i recently sold the bike, so i have no use for it. THESE PRICES ARE SHIPPED, MUST LIVE IN THE 48 CONSECUTIVE STATES.
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- gumby prichard
03 Sep 2012 16:51 - 03 Sep 2012 16:51 #546425
by gumby prichard
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
Replied by gumby prichard on topic kz400 2 into 1 setup and keihin 35mm carb
also i will include all the jets i have fore it which there are at least three differen sizes for the main. i will post sizes later along with pictures.
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
Last edit: 03 Sep 2012 16:51 by gumby prichard.
- treitz
- Thank you received: 2
04 Sep 2012 11:38 #546574
by treitz
1979 KZ400 - 2-1 Manifold - Mikuni VM34
Replied by treitz on topic kz400 2 into 1 setup and keihin 35mm carb
I am very interested!
Does the carb come with the throttle set up also? What about air filter?
Send me a private message. I would like first dibs assuming everything looks good. I will PM you my phone number as well.
- gumby prichard
04 Sep 2012 14:32 #546613
by gumby prichard
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
Yes, it does, comes with throttle and throttle cabel, i might add it is a flat slide carb. like i said only thing it needs is the idle screw and spring.(may want to replace the 4 float bowl screws too, the heads are a little stripped but you can still get them out.
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
- gumby prichard
10 Sep 2012 18:47 #547872
by gumby prichard
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
SOLD
78 kz750 twin
77 yz125
91 cr250
99 dr650
ex's:
78 kz400 b1
89 yz80
99 klx300
