bad leak
- Kmalo86
31 Aug 2012 14:50 #545894
by Kmalo86
bad leak was created by Kmalo86
i just bought a 77 kz750 and there seems to be a pretty substantial leak coming from the carbs or so it appears fuel lines have been replaced but still continues leaking any ideas would be greatly appreciated
- bountyhunter
- Thank you received: 337
31 Aug 2012 16:43 #545917
by bountyhunter
Replied by bountyhunter on topic bad leak
If you mean gas leaking out the overflow tubes, it's a problem with the floats or check valves.
- Thank you received: 2098
31 Aug 2012 18:37 #545934
by Patton
Would first determine exact site of the leak.
Replied by Patton on topic bad leak
Kmalo86 wrote: i just bought a 77 kz750 and there seems to be a pretty substantial leak coming from the carbs or so it appears fuel lines have been replaced but still continues leaking any ideas would be greatly appreciated
- ironslave
- sup
31 Aug 2012 18:44 #545936
by ironslave
1981 KZ750 LTD
Replied by ironslave on topic bad leak
if it is a vacuum type design the petcock will have a prime position instead of an off position. It is possible the vacuum controlled valve is not working correctly and is sticking open. I had this problem. I just moved the positions back and forth and rode it until it stopped. It didn't take long.
1981 KZ750 LTD
- bountyhunter
01 Sep 2012 00:50 #545985
by bountyhunter
The 77 KZ750 is not a vacuum petcock, just a crappy mechanical valve that likes to leak like a mutha.
