modifyng BS34 CV carb slides
- jga2z
- 2 wheels good ,4 wheels bad
30 Aug 2012 13:32 - 30 Aug 2012 13:34
I read a thread that talked about the problems in running pods on CV carbs which detailed the issue of lower vacuum in the carb without a stock air box. This is my take. The free flow of air causes the slides to not raise as much (since they operate on vacuum) which in turn causes poor midrange performance. One remedy was to restrict the air flow of the pods. I found another site that described a mod that could be made which might compensate for the pods.
CV carb mod
Namely to drill the hole in the bottom of the slide to allow for more response from the slide/diaphragm given the lower relative vacuum.
Has anybody tried this?
Since the slide needles aren't adjustable on this bike I thought this mod might help some.
currently 1982 LTD1000 UNI dual throat pods, MAC header Supertrapp muffler. Shoei fairing.
The good old days: 1977 KH 400 triple, 1978 KZ650B all the basic mods, My avatar a 1980 LTD 750, ditto on the mods
Last edit: 30 Aug 2012 13:34 by jga2z.
- BlackZ1R
- Kawasaki in my blood
Re: modifyng BS34 CV carb slides
30 Aug 2012 17:31
It will help somewhat, along with shimming the stock needles 1-2mm. The best way to deal with the lean midrange problem with these carbs running pod filters is to replace the jet needles with ones that have a better taper profile for performance.
The Dyno Jet kit needles have a great profile, and the instructions also call for drilling the holes in the slides.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- jga2z
31 Aug 2012 13:15 - 31 Aug 2012 13:18
The current slide needles have no taper at all. If I shim up the needles in the slide will the plastic disc that holds them down in the slide need to be altered?
Can I get just the dyno jet needles alone? I've already got 127.5 mains and #40 pilots.
Last edit: 31 Aug 2012 13:18 by jga2z.
- jga2z
Re: modifyng BS34 CV carb slides / needles
31 Aug 2012 14:11
I'll answer my own question. I called Z1 and Dyno, and you cannot get just the needles
Are there any stock needles that are adjustable and /or have some kind of taper to the tip?
- Motor Head
02 Sep 2012 14:43
There is an old KZR post with these needles being used. But I have not tried this, as I run an AirBox. Also the stock 81-82 A-1 A-2 shaft drive needle has more Taper, but still only one notch.
www.mikesxs.net/product/48-0663.html
The following user(s) said Thank You: BlackZ1R
- BlackZ1R
02 Sep 2012 15:18jga2z wrote: I'll answer my own question. I called Z1 and Dyno, and you cannot get just the needles
Here is a thread on the Mikuni needles that are very close to the 5GX29 a 5 clip adjustable needle used in the KZ1100-A non-US models. Sounds like the ticket. Let us know how it werx for you!
Good post Motor Head!!!
kzrider.com/forum/3-carburetor/519737-je...-limited-mods#525572
Kawasaki
- jga2z
03 Sep 2012 16:12
The link to mod in my first post said to drill out the hole in the slide to 1/8". Does any body say different? The slide needles IIRC do have a taper, but no adjustment for clip. I am going to try the shim method first before getting new needles.
The 83 1100 L1 I'm working on has slide needles with no taper?!?
- Motor Head
03 Sep 2012 16:40
Without a more aggressive taper to the needle, shimming will help the lower end of the throttle, but I doubt it would be enough for the 1/2 throttle up. I'd get some needles, or just buy the Dyno-Jet kit, if you want the Pod's.
- BlackZ1R
03 Sep 2012 16:44
I would go with what Dyno Jet recommends in their kit, a #37. Being how they do Dyno engineer their kits, they have a good data bank of what works and what doesn't.
If you don't have a #37 or can't find one, we use a 7/64 drill bit on our CVK slides. #37 is .104 , and the 7/64 is .109 dia. 1/8 is .125.
I'd rather have it too small than too large. If you go too big, you can close it back up with epoxy then drill it with a smaller bit if you need to.
Kawasaki
- BlackZ1R
03 Sep 2012 16:46Motor Head wrote: Without a more aggressive taper to the needle, shimming will help the lower end of the throttle, but I doubt it would be enough for the 1/2 throttle up. I'd get some needles, or just buy the Dyno-Jet kit, if you want the Pod's.
+1 what he said You beat me to it Motor head
I have a set of needles out of an ELR 1000 that look like straight rods with a bevel on the end that goes in the jet :woohoo: Dang those things are L E A N !! :lol:
Kawasaki
