carb problems
- rideing soon 1980
- gd4now
- Denco where did you go?
- Thank you received: 445
Make sure you do not have any air/vacuum leaks on the carbs holders or any of the vacuum ports.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- Thank you received: 2098
- rideing soon 1980
rideing soon 1980 wrote: Sorry i shoulda been more clear the carbs are supposet to be stock 24's miluki's. It back fires gas out the carbs when it carnking but dose start after about 3-4 turn overs. Goes right to high chopy idle then when u rev it up back fires and shoots a flame thats about a foot. I rode the bike and the first 1/3 throttle is chopy but opens up to decent responce but back fires in between shifts while letting off the gas. Im trying not to take it to a shop as i already have 3x's in it what i paid for it. And my cheap get around is becomming a money pit. Any ideas on what i might be able to do? The bike ran great before the slide froze up. Im running an open header with the stock air box.
slide froze up :huh:
- tinlizzie37
- Thank you received: 1
Bob KZ 650 E1, En 450
- rideing soon 1980
- gd4now
If you were to post the IDs from the carbs I may well be able to tell you what models / years they were used as stock carbs.
See pics for location of ID stamp and some tables I created with what I think are the stock carbs and internal used on the 650s. Just keep in mind I in no way wish to indicate the tables are 100% accurate, but I do feel they are close.
1977 KZ650 B1
- rideing soon 1980
- Thank you received: 2829
Attachment Bobber_2012-09-02.jpg not found
