Vm29's jetting on a '77 1075
- BrandonTKZ
Thanks, Brandon.
1977 KZ1000 ~ Wiseco 1075cc
- moneypit
- Thank you received: 35
2-76 kz900
St Paul MN
- zukdave
- Thank you received: 229
and am playing with 117, 120 and 122.5 main's.
At 1075 I'd sell the 29's to fund a
lot bigger set of carb's
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
- BlackZ1R
- Kawasaki in my blood
- Thank you received: 47
Sounds like you may have a different problem than jetting. Check for full voltage to the coils first.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- kzz1king
- Thank you received: 52
Wayne
Home built KZ1000 turbo setup
- saxjonz
- KawboyZ
- Thank you received: 76
79 LTD B3
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- BlackZ1R
kzz1king wrote: How many turns out are you all running on the air screws? I am at 1 but read where some are down to 1/4.
Wayne
Is this a street or strip bike. I'm running 29s with 17.5 pilots on a street bike with a stock 1015 engine. I get a good bit of lean popping at 1/8 throttle and below, at 1/2 to 3/4 turns out on the screws. 1/4 turn out didn't idle well.
In my way of thinking, the carbs are designed for 1 1/2 turns out on the air screws to emulsify the idle fuel mixture correctly, I'm thinking go up on the pilots until you are getting the proper volume of air moving through the idle circuits.
Not only will you have the proper A/F mixture at idle, you will have plenty of fuel flowing right off idle before the needle takes over. Am I not thinking about this the right way?
Kawasaki
- gd4now
- Denco where did you go?
- Thank you received: 445
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- BlackZ1R
I've gotten tired of thinking about this and went out and took the carbs(29s) off my bike. Gonna try some different pilot jets and see for my self how this will work out...building a carb stand now Anyone have a Colortune they want to sell???? :whistle: :lol:
FWIW, an it may not mean anything, I screwed the air screw all the way in and backed it out to 1 1/2 turns while watching the hole in the air screw through the idle air passage. At lightly seated position you could see the top edge of the hole, at half turn out, 1/3 of the hole was visible, 1 turn out, more of the hole, until at 1 1/2 turns out the hole was lined up in the idle air port. Maybe a coincident, I only got to do it on one of the carbs.
Kawasaki
- kzz1king
Wayne
gd4now wrote: You need to keep in mind that the air screws on the 29s work a little different than they do on the other mikuni vm carbs. On the 29s the air screw has a hole in it near the end. So you should not need to turn them out as far as you would on the other carbs - I think a good starting point is about 1/4 turn from lightly seated.
- BlackZ1R
Here is some good info to wrap your mind around:
www.iwt.com.au/mikunicarb.htm
Kawasaki
