Float Height/Fuel in bowl
- gremlin497
25 Aug 2012 12:44 #544706
by gremlin497
1977 KZ 1075 (FBG), 29 Smoothbores V&H Mega
Float Height/Fuel in bowl was created by gremlin497
Today is tuning day. I have VM 29 smoothbores (A7) and need to know how much fuel should be in bowl. Dont have plug to see how much fuel is in there unless I take bowl off. I know that float height is suppose to be 23mm, and that was dont. Should bowl be 1/2 full 3/4 full or totaly full ? Any help would be great.
- Thank you received: 2829
25 Aug 2012 12:55 - 25 Aug 2012 13:01 #544710
by 650ed
Replied by 650ed on topic Float Height/Fuel in bowl
Each carb bowl should have a drain plug on the bottom. You should be able make an adapter with a nipple on it that can be used to do a clear tube test. Ed
kzrider.com/forum/11-projects/543641-z1-...t=20&start=20#544660
Last edit: 25 Aug 2012 13:01 by 650ed.
