1983 Kz550 overflow pours gas
- nab
22 Aug 2012 21:27 #544177
by nab
1983 kz550
1983 Kz550 overflow pours gas was created by nab
Tried to find info on possible causes but came up dry for my carbs. My bike has the vacuum slide carbs with the flat tops. I recently replaced the petcock with a non vacuum petcock and a inline fuel filter. I went through the carbs already and cleaned them thoroughly and the bike ran fine so im thinking a stuck needle valve because it pours gas out as fast as the petcock can flow it. My real question is where can I get one that is definitely for my carbs?
Thanks,
Ben
Thanks,
Ben
1983 kz550
- Thank you received: 2098
22 Aug 2012 22:09 - 22 Aug 2012 22:09 #544194
by Patton
If gasoline is escaping from the overflow nipple, would also check for a cracked or loose overflow tube.
Replied by Patton on topic 1983 Kz550 overflow pours gas
nab wrote: Tried to find info on possible causes but came up dry for my carbs. My bike has the vacuum slide carbs with the flat tops. I recently replaced the petcock with a non vacuum petcock and a inline fuel filter. I went through the carbs already and cleaned them thoroughly and the bike ran fine so im thinking a stuck needle valve because it pours gas out as fast as the petcock can flow it. My real question is where can I get one that is definitely for my carbs?
Thanks,
Ben
Last edit: 22 Aug 2012 22:09 by Patton.
- Jhenry
22 Aug 2012 23:49 #544215
by Jhenry
Replied by Jhenry on topic 1983 Kz550 overflow pours gas
Z1 Enterprises or Sudco will have the float needle and seat, if that is in fact the issue. Patton mentioned one good possibility. Another is a stuck float. I had the same thing happen in the middle of a poker run one time and my friend told me maybe the float is stuck. So I kicked the cab with the toe of my boot. Stopped it right off. Harley guy said "I thought Jap bikes never gave any problems but that guy has to kick his into submission". I thought it was funny anyway. It ended up being a nice ride.
Good Luck!
Good Luck!
23 Aug 2012 05:10 #544257
by Patton
With some carbs, it might be possible that the float was installed upside down when reassembled.
