Inline Visu-filter junk
Re: Inline Visu-filter junk
29 Dec 2012 23:24
If a bike is kept in good condition & a fuel tank is rust free, then would an in-line filter be necessary?
His are probably well maintained.
- loudhvx
30 Dec 2012 16:20
That has been my experience with that type of filter. Eventually one of the ends will get soft enough to pull off like a Twizzler, just not as tasty.
Now I use those metal ones, as pictured above, but you have to make sure to screw them together tight enough or they can leak.
I'm also still using this one from Z1Enterprises, which so far hasn't softened like the cone-shaped filters. I expected it to, but I've had it for 3 years now.
www.z1enterprises.com/ItemDetails.aspx?i...2f4%22&item=MA2345-1
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 22 Jan 2013 23:46 by martin_csr.
- tinlizzie37
31 Dec 2012 22:10
I got my inline at a Honda dealer for a couple bucks. It's been on the bike for 4 years now and is still solid, last time I looked. Bob
Bob KZ 650 E1, En 450
- razzman
31 Dec 2012 23:21
It has been my experience that an inline filter is not only adviseable, but rather mandatory to insure a clean supply of fuel to the carbs. I know that there is a filter in most OEM and aftermarket petcocks, but to rely solely on them is asking for trouble. Even the aftermarket "junk" is, in my opinion, is better than nothing. It is obvious by the posted picture that something is going on, whether it be gas, additives, etc.. I guess I could imagine what it would have looked like once it reached the carbs. I get 'em everyday clogged up with junk. The common demonenator: no inline filter. Of course, everyone has their own opinion. Ride on Brothers.
Spyder
Spyder
Ride like you're invisible,
Spyder
Spyder
- zukdave
01 Jan 2013 01:13
I don't run the filter tubes in my tank
so in line is a must.
We have some at work that work with the ethanol.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- lushbaugh
- everybodys a pro......
01 Jan 2013 01:21
trusting hundreds and thousands of dollars to a two dollar part lol.... i use the best filter i can get my hands on.
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
- RonKZ650
01 Jan 2013 03:46 - 01 Jan 2013 03:50
I rode like 200,000 miles without this aftermarket crap on KZs and did fine, then thought I'd add one. I don't need the chinese crap. Why oh why aftermarket??? Chinese crap over and over and over again. They don't care they build and sell utter crap over and over again? I just don't understand the attraction to add ons, 99% of which are junk. I was a little dumb I guess, got these from Bikebandit and they listed them as some term, which I can't think of, but something along the terms of a rack, or pegboard of filters?
I thought I was getting like 20 filters for the $9.95 or whatever it was. I got ONE. $9.95 for one junk filter made in China :sick: I'll just clean my carbs once every 50,000 miles for free. Junk, JUNK. I'm fed to shit with add on fricking shit that turns to crap in one day.
Last edit: 01 Jan 2013 03:50 by RonKZ650.
- lushbaugh
01 Jan 2013 04:05
hahahaha i agree for the most part and many people like wireman will as well. alot is simply bling. but theres a big difference between aftermarket performance and chang jiang universal parts. alot of the time if not all of the time you get what you pay for.
- GPz550D1
02 Jan 2013 11:33
No Chinese junk fuel filter on my bike!
1981 KZ550-D1
- Kidkawie
- I bleed premix
02 Jan 2013 15:08 - 02 Jan 2013 15:12
Only if there's no filter on the petcock tubes. You can find them aftermarket, just search "petcock filter".
Also, there's a debris trap in most petcocks that people tend to forget about.
This and a small clamp would work.
martin_csr wrote: If a bike is kept in good condition & a fuel tank is rust free, then would an in-line filter be necessary?
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
Last edit: 02 Jan 2013 15:12 by Kidkawie.
- wagonmaster69
- 78 KZ1000A2 / 82 KZ1100 Spectre
05 Jan 2013 01:51
I went to a lawn mower repiar and part shop and got some that had a 90o from inlet to outlet.
