Inline Visu-filter junk
  • RonKZ650
  • RonKZ650's Avatar Topic Author
21 Aug 2012 11:36
#543850
Maybe this is the dreaded ethanol effect? Don't know or care, but this filter *was* a straight through filter last I looked. I go out to ride to work last Friday and have a huge gas leak because the thing did this and the fuel line pulled off.
  • pete greek1
  • pete greek1's Avatar
Re: Inline Visu-filter junk
21 Aug 2012 11:44
#543854
was it too close, or touching the engine ?
  • RonKZ650
21 Aug 2012 12:07
#543866
No, it was just a straight run from the carbs up to the petcock. This all happened when the bike was sitting in the garage. I've only ridden it around 50 miles this summer. Somewhere between the last ride and last Friday it decided to soften and bend.
21 Aug 2012 12:31
#543876
RonKZ650 wrote: ...huge gas leak because the thing did this and the fuel line pulled off....
Another reason to turn off the petcock when parked.
Presents a situation where perfect float valves can't save the day.
Good Fortune! :)
  • OldSchoolZ
  • OldSchoolZ's Avatar
21 Aug 2012 12:43
#543880
By looking at that filter. I would take a good look inside my tank, it looks packed with stuff.
Remember, don't work on your bike so much you never ride it.
  • martin_csr
  • martin_csr's Avatar
21 Aug 2012 13:02
#543886
I've encountered the same thing, although not as severe... the ends were bendy.
After seeing that one, I guess I'll look into one w a metal body - either Emgo or Pingel.
  • RonKZ650
21 Aug 2012 13:51 - 21 Aug 2012 13:52
#543901
See why I pretty much tout all aftermarket as garbage? Everything I get though aftermarket always ends up this way. ;)
Last edit: 21 Aug 2012 13:52 by RonKZ650.
  • MFolks
  • MFolks's Avatar
21 Aug 2012 13:56
#543904
Ethanol In Gasoline Problems (E-10, E-15, E-20, E-30, & E-85)
The Ethanol in the gas has been reported to attack the glue used in gas filters, rendering them useless, as the paper filter medium is now coated with glue. It also softened the filter hose connection ends, causing possible failure.
  • ezrider714
  • ezrider714's Avatar
22 Aug 2012 01:09
#544014
For sure a fuel compatibility issue,
However you give no clue type of fuel used? :unsure:
Around here in Ohio, pure gasoline can still be located,usually at places catering to race car crowd,
also some stations have Premiun that is ethanol free.
Any early Kaw should not be using Regular, pricey maybe, but pay me now or pay me later.
You see the filter, now just imagine every, oring, gasket, seal and even some metal
parts in the fuel system and what they are turning into. :(
I'd switch fuel suppliers, and maybe some Sta-Bil ethanol treatment and cross my fingers :unsure:
78 KZ650SR Mine since 79
4-1 Mac Jet Hot coated since mid 80's
Dyna Coils
Saddlebags (I ain't skeered of going nowhere) :)
  • RonKZ650
22 Aug 2012 11:33
#544072
Around here it's mandated by law we run ethanol in the gas for most the year so we have no choice. I've never had any problems all these years up until now. I never ran an inline filter and never saw the benefit really. Now I really don't see the benefit. Another add-on that is Chinese junk most likely.
22 Aug 2012 11:57 - 22 Aug 2012 12:00
#544082
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationA few of the current offerings --
Pingel selection --
www.motorcycle-superstore.com/1/4/457/20...ilter&WT.MC_ID=10010
www.motorcycle-superstore.com/1/4/457/79...ies-Accessories.aspx
Some folks caution against using the glass versions on motorcycles.
Good Fortune! :)
Last edit: 22 Aug 2012 12:00 by Patton.
29 Dec 2012 13:28
#565077
RonKZ650 wrote: Around here it's mandated by law we run ethanol in the gas for most the year so we have no choice. I've never had any problems all these years up until now. I never ran an inline filter and never saw the benefit really. Now I really don't see the benefit. Another add-on that is Chinese junk most likely.
I wouldn't run a bike WITHOUT an inline filter unless you like cleaning carbs!Never had an issue, right? You will... "Just Sayin"
GHOSTRIDER,1980,KZ1000ST
