Float Bowls Leaking Gas
- raulfd4
20 Aug 2012 09:24 - 20 Aug 2012 09:25 #543581
by raulfd4
1980 Kawasaki KZ440A
Float Bowls Leaking Gas was created by raulfd4
1980 KZ440. See attached diagram of carburetor.
My float bowls leak gas pretty badly when the bike is running. I bought a carb repair kit and replaced parts 17 and 23 in the diagram (gaskets and gas shut-off thingy). I also slightly bent the "tang" on part 15 (the floats) in the red circle so that the gas would shut off a little sooner.
I put everything back together and the bike started up okay, but it still leaks gas. It seems like the gas is leaking around part 24 (overflow screw?). The screw is as tight as it can get.
Any ideas?
Any ideas?
Attachment FloatBowl.png not found
Last edit: 20 Aug 2012 09:25 by raulfd4.
- Thank you received: 1656
20 Aug 2012 10:24 - 22 Jan 2013 21:13 #543589
by martin_csr
Replied by martin_csr on topic Float Bowls Leaking Gas
never mind wrong carbs
Last edit: 22 Jan 2013 21:13 by martin_csr.
- Thank you received: 2098
20 Aug 2012 10:24 - 20 Aug 2012 10:25 #543590
by Patton
Replied by Patton on topic Float Bowls Leaking Gas
Part 25 might be a damaged o'ring.
Just to be on the safe side, would sniff-test and examine condition of oil to determine whether it might be contaminated from gasoline intrusion into the crankcase.
Last edit: 20 Aug 2012 10:25 by Patton.
