- Thank you received: 35
Accel pump bypass?
- lushbaugh
- everybodys a pro......
17 Aug 2012 07:58 #543033
by lushbaugh
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
Accel pump bypass? was created by lushbaugh
So my bikes my only ride and i need it, both diaphrams are shot and i think thats why i keep loosing a cyl and gas in oil. Anything i can do? there 28 pumprs btw
- wireman
- Thank you received: 299
17 Aug 2012 10:09 #543045
by wireman
Replied by wireman on topic Accel pump bypass?
Disconnect the rod from carbs
- lushbaugh
17 Aug 2012 11:33 #543065
by lushbaugh
Replied by lushbaugh on topic Accel pump bypass?
Cant cause the sensor diaphram is rotted out also, causing the leak into the cylinder, but wait it gets better, no one sells one near me so i started pulling down my flatsides to possibly set those up and i have an emulsion tube snapped of in the carb body wtf!
- BlackZ1R
- Kawasaki in my blood
- Thank you received: 47
17 Aug 2012 12:39 #543073
by BlackZ1R
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
Replied by BlackZ1R on topic Accel pump bypass?
Hey, try building a block off plate for the pump.
Sounds like you have a couple float valves leaking causing your main gas in oil problems. I had similar problems with my 28 pumpers. The petcock was toast. A Pingel solved most of those problems.
The flat slides sound like a bust trying to get them up and running.
Send me a pic of the carb body, I may can fix that for you.
Kawasaki
- lushbaugh
17 Aug 2012 12:58 #543079
by lushbaugh
ok ill snap a pic, do you do carb work?
- lushbaugh
17 Aug 2012 13:06 #543082
by lushbaugh
One showing whats missing and one of the stubbed off one. I tried heating and threadin into it but i think its gotta be drilled
- pete greek1
- Thank you received: 185
17 Aug 2012 13:08 #543083
by pete greek1
Replied by pete greek1 on topic Accel pump bypass?
Oink has a set of 28s with accelerator pump for $102.50 with about 10 hrs left
- lushbaugh
17 Aug 2012 13:13 #543085
by lushbaugh
- lushbaugh
17 Aug 2012 14:08 #543093
by lushbaugh
bit the bullet and baught a rebuild kit for the 28s since my flatsides are bitched up. im so mad im wasting money i dont really have and could put into the rs34s. i think im gonna send them off to be repaired and set up to a good start point wile i run the 28 pumpers. talk about frustrating dumped 250 on the rs34s knowing they needed rejetted and its one thing after another, everything on this bike is fighting me.
- kawasaki mike
- kawasaki mike
06 Sep 2012 22:20 #547171
by kawasaki mike
Am addicted to Z1's and kz 900's have an el camino, fly rc helicoptors and am strung out on horsepower.
Replied by kawasaki mike on topic Accel pump bypass?
I feel your pain man. I have a set of 28mm vm sc early style carbs set up for 1200 ft elevation with a kz 1000 with air filter pods and open 4 into 1 pipe that work very well. (no leaks0 and great throttle response. You can have-em for 250 if you pay shipping. Call me 701 425 7461. I am in Las vegas(mike)
- lushbaugh
08 Sep 2012 19:02 #547524
by lushbaugh
i have flatsides i wanna get on her, but thank you
