- Thank you received: 10
Petcock fabrication
- Kitten Tooth
14 Aug 2012 04:15 - 14 Aug 2012 04:37 #542473
by Kitten Tooth
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Petcock fabrication was created by Kitten Tooth
Here are some pictures of a fuel tank valve that will be going on my bike soon.
Consists of a 1/4 inch ball valve, 1/4 inch nipple (for main hose), and a small double threaded tube. If you dont have these parts just laying around and go to Menards for them, it all comes to about 10 bucks. Everything after that is just time for the metal casting process :evil: . Here are all the parts lying out.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Last edit: 14 Aug 2012 04:37 by Kitten Tooth.
- Kitten Tooth
14 Aug 2012 04:22 - 14 Aug 2012 04:38 #542474
by Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Replied by Kitten Tooth on topic Petcock fabrication
This is the stock petcock that has been giving me trouble the whole time i have owned the bike. No matter how much i clean the damn thing, it always leaks and contaminates my oil. I dont want to put in one of those in-line plastic valves because it seems tacky and rigged. I would like to just install a simple on off valve.
The bike all these parts are going on is my 81' KZ1000LTD pictured below. (yes shes a wee bit ratty at the moment :whistle:
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Last edit: 14 Aug 2012 04:38 by Kitten Tooth.
- Kitten Tooth
14 Aug 2012 04:24 #542475
by Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
And heres the mounting plate all covered in sheetrock mud and ready for casting. The sprew is coming out where a hole will be tapped in for the valve. The plate with the holes in it is where it will bolt to the tank.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Kitten Tooth
14 Aug 2012 04:28 #542476
by Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
More to come soon of the valve in action. I also plan to replace the on/off lever on the valve with a smaller one. This valve will eliminate the vacuum tube coming from the carbs. Basically just a line out much like a Pingel petcock.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- baldy110
- Thank you received: 512
14 Aug 2012 15:04 #542576
by baldy110
Replied by baldy110 on topic Petcock fabrication
- Kitten Tooth
14 Aug 2012 17:33 #542600
by Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Mine should clear the carbs as well. I may be switching out the valve with a smaller one but that was the best i could get at the store. That looks pretty clean though.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Kitten Tooth
15 Aug 2012 03:40 #542712
by Kitten Tooth
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
Well the mating plate short poured last time while casting so I made another part out of foam. Painting the sheetrock mud on and added vents this time. Also, im going to drill the holes after its casted instead of drilling them into the foam. Made the plate a little bit bigger on this one too because foam shrinks after cooling off.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Kitten Tooth
15 Aug 2012 03:43 #542713
by Kitten Tooth
Haha, well low and behold after you asked if it would clear the carburetors i went and checked. The output nipple runs right into the manifold boot on cylinder 1 :pinch: . Not a problem though, Ill just put the valve on the side of the casted part rather than on the bottom. Should look good and the lever will turn in, under the tank, so you dont bump it while riding. Should work awesome when its all finished
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
baldy110 wrote: that is a different approach, is the ball valve small enough to fit without hitting the carbs?
Here a pic of mine.
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
