79 kz650 carb swap
- rideing soon 1980
10 Aug 2012 14:07 #541761
by rideing soon 1980
79 kz650 carb swap was created by rideing soon 1980
Question,i have a 79 kz650b im needing to swap carbs on as mine are unuseable. I have found several on ebay but im not sure what i can swap mine out with. Do i need something with the acc. Pump or dose that make a difference. Dose it matter if its a b,c,d or what not? Thanks for the help. Its much apperaited!
- Thank you received: 1656
10 Aug 2012 16:40 - 11 Aug 2012 11:48 #541787
by martin_csr
Replied by martin_csr on topic 79 kz650 carb swap
You can use the VM24 carbs from any KZ650. Also, you should be able to use the BS32 carbs from the 82-83 CSRs, but w those you'd need the carb holders, airbox ducts, & airbox. With the BS32s one fitment problem might be that the petcock may bang against the #1 carb, but an alternate petcock may be available (aftermarket Suzuki unit from Z1Enterprises.com).
Last edit: 11 Aug 2012 11:48 by martin_csr.
- rideing soon 1980
14 Aug 2012 11:56 #542529
Replied by rideing soon 1980 on topic 79 kz650 carb swap
Much thanks for the info. Now hopefully i will be able to get on the road before rideing season is over. Again much thanks for the help.
