- Thank you received: 2
'83 KZ550 A4 - Alternative Carb Setup
- PtownSLUG
09 Aug 2012 04:44 #541522
by PtownSLUG
81 GPz 550
'83 KZ550 A4 - Alternative Carb Setup was created by PtownSLUG
I currently have the stock CV TK26 barbs. I'm trying to find out what options I have for a direct swap, as in a carb set that will line up perfectly with my motor. I'm looking for mechanical carbs.
Thanks!
Thanks!
81 GPz 550
- Thank you received: 1656
09 Aug 2012 10:05 - 22 Jan 2013 21:06 #541536
by martin_csr
Replied by martin_csr on topic '83 KZ550 A4 - Alternative Carb Setup
You might be able to use the carbs from the earlier 550s. You're probably going to have to get the carb holders & airbox ducts. KZR member loudhvx has a good motorcycle stuff page w lots of KZ550 info - he has a link in his signature.
Last edit: 22 Jan 2013 21:06 by martin_csr.
- PtownSLUG
09 Aug 2012 22:33 - 09 Aug 2012 22:34 #541625
by PtownSLUG
81 GPz 550
Replied by PtownSLUG on topic '83 KZ550 A4 - Alternative Carb Setup
Thanks martin.
Looks like the earlier kz550 has TK22 carbs. I see a couple on ebay. There's also a guy here in my area that is selling a couple boxes of '78 kz1000 parts, including the carbs. Anyone know exactly what carbs a '78 kz1000 has and if they would fit my kz550?
81 GPz 550
Last edit: 09 Aug 2012 22:34 by PtownSLUG.
- loudhvx
- Thank you received: 1616
10 Aug 2012 13:46 #541758
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic '83 KZ550 A4 - Alternative Carb Setup
The only carbs I know of that have the same spacing as the TK26 cv's are the TK27 cv's from the ZX 550 A motors, and the TK22 mechanicals from the first-gen KZ550 motors (KZ550A1-A3, C1-C4, D1).
The TK27 is a direct swap.
The TK22 requires you to modify the intake manifolds. The 2nd gen motors have the same carb spacing, but the manifold bolts are farther apart. You just have to notch out the bolt holes on the manifolds (aka carb holders), then use thick washers on the bolts. You may want to convert to stainless allen screws that are a tiny bit longer to make up for the washers. The only other issue is that the ports are bigger than the manifolds. There is enough wall-thickness on the manifolds to cover the ports, but that change in diameter puts a step change in the intake tract which leads to the accumulation of gasoline under certain circumstances. This just means jetting can be a little trickier. Jetting evaluations are better done over a long period of time so you can get to know how the carbs behave. Obviously, because they are mechanical carbs, you can no longer just mash the throttle.
Z1 enterprises has new carb intake manifolds from the early motors, which is what you would need to install the TK22 carbs on a 2nd gen motor. Unfortunately, it looks like the price just took a huge jump up.
www.z1enterprises.com/ItemDetails.aspx?item=16065-1014X4
1981 KZ550 D1 gpz.
Other links.
The following user(s) said Thank You: PtownSLUG
