Do I go as big on main jets if.....
- Knight Rider
08 Aug 2012 01:07 #541313
by Knight Rider
1976 kz900 1075 435 cams ported head sidewinder
Do I go as big on main jets if..... was created by Knight Rider
I have carbs with an accelerator pump? Using some rules of jetting with pods and four into one I should go up one pilot size and three in the main. But do I have go as high with the mains because of he pump? I know the pump does not help at wot but I was thinking that the main being bigger might b richer to help with acceleration.. What y'all think?
Knight Rider out!
Knight Rider out!
- Nebr_Rex
- Thank you received: 300
08 Aug 2012 04:56 #541324
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic Do I go as big on main jets if.....
What does your engine tell you.
My '79 ST,1105,.395,stock pumpers and exhaust.
17.5,,raised 1 and stock 110 mains
With an exhaust analizer idle was fine,mid range is rich,but top end went way lean.
I thought it was the 28s being to small for an 1105.
I'll try 115s and drop the needles 2 from what they are now.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Motor Head
- Thank you received: 391
08 Aug 2012 09:43 #541342
by Motor Head
Replied by Motor Head on topic Do I go as big on main jets if.....
Accel pump and main jet size would be unrelated. Pump will bottom its diaphragm around 1/2 throttle or less, stopping nozzle delivery. It is only a shot of fuel for acceleration, in the first 1/2 throttle or so depending on adjustment.
- gd4now
- Denco where did you go?
- Thank you received: 445
08 Aug 2012 13:13 #541365
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic Do I go as big on main jets if.....
I agree the fact you have an accel pump should not play a part in the main jet size. Keep in mind the "rules" you mention regarding jetting for mods are just a general starting point and not what your machine may need in your location. You will have to test, plug chop, roll on, roll off etc or use an exhaust gas analyzer to find the proper jetting and tuning.
1977 KZ650 B1
- Knight Rider
08 Aug 2012 16:57 #541411
by Knight Rider
Replied by Knight Rider on topic Do I go as big on main jets if.....
Thanks guys. Makes sense.
Knight Rider out.
Knight Rider out.
