79' KZ400 Air Box Removal Help
- CafeKid
06 Aug 2012 01:27 #540929
by CafeKid
'79 KZ400
79' KZ400 Air Box Removal Help was created by CafeKid
Just trying to remove the air box on my 1979 KZ400 and I cant seem to find the page in the manual im looking through.
Does anyone have Page 43 of the 78' - 81' KZ400 workshop manual? Or know how to remove the air box on these models?
Thanks!
Thanks!
'79 KZ400
- Nebr_Rex
- Thank you received: 300
06 Aug 2012 12:46 #540987
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic 79' KZ400 Air Box Removal Help
Did you check the filebase or KZ400.com ?
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Killman
- Now with 99% more ducks
- Thank you received: 12
06 Aug 2012 13:11 #540992
by Killman
1983 kz440 ltd
Quack
Replied by Killman on topic 79' KZ400 Air Box Removal Help
Is it an ltd? I can probably email you the pages you need.
1983 kz440 ltd
Quack
- faffi
- Thank you received: 36
06 Aug 2012 17:11 #541040
by faffi
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
Replied by faffi on topic 79' KZ400 Air Box Removal Help
I have a '79 stripped frame. The airbox is still in it. I suspect the frame was welded around the darn box :lol:
1977 KZ650B1
1980 F1 engine
B1 Points ignition
- mwriders
- if I only had a brain
- Thank you received: 6
06 Aug 2012 17:17 #541043
by mwriders
1980 Kawasaki KZ440B (brand new eBaby)
1998 Ducati 900S (gone)
1978 BMW R100S (gone, damn it)
1975 Yamaha RD350 cafe (gone)
1986 Yamaha XJ650 Seca (gone)
1981 Kawasaki KZ440LTD (gone)
1969 HD Sportster (gone
1966 Honda CB160 (gone, damn it)
1965 Suzuki 80
Replied by mwriders on topic 79' KZ400 Air Box Removal Help
Are you planning on totally removing the box, or just getting it back far enough to service the carbs? Don't know which model you are working on, but if you want it completely out, remove the rear wheel, battery box (on the B's anyway) and regulator, remove the inner fender liner and slide the thing out the back. At least, that's how mine worked. But like I said, it's a B. If all you want to do is get to the carbs, pull the battery, regulator and plastic inner fender and you'll have enough room.
1965 Suzuki 80
The following user(s) said Thank You: CafeKid
- CafeKid
06 Aug 2012 18:58 #541057
by CafeKid
'79 KZ400
Replied by CafeKid on topic 79' KZ400 Air Box Removal Help
Thanks for the quick replies guys!
Nebr_Rex - I've checked kz400.com and they're missing the page on the pdf file as well.
and filebase? not too sure if thats forum related or a file sharing site?
Killman - I dont believe its an LTD but any info I can get certainly helps! I'll shoot you my email in a PM.
faffi - Haha! I feel the same way, but i know its got to have some wiggle room. Just wondering if I'll need to remove the rear tire as well. :blink:
mwriders - Exactly, just trying to get at the air box to service the carbs and check out the airflow in the box. The bikes right cylinder is running rich so I'm trying to eliminate the factor of improper airflow before I move on.
'79 KZ400
