Just cleaned the carbs now my kz wont run
- Wristwist
05 Aug 2012 15:41 #540855
by Wristwist
Sunday back road rider
Just cleaned the carbs now my kz wont run was created by Wristwist
I have an 83 kz550 ltd and when I got it it was running great. I ran a couple tanks of through it and the overflows started leaking. I took the carbs off and cleaned the bowls and float needles. To say reinstallation was a pain is a huge understatement! Anyway, got them on after wrestling the air ducts for a while. Now when I try to start it it seems like it is starving for fuel b/c it tries to crank but of I give it throttle it just dies. I really want to ride again and now wish I had never taken it apart. Any insight is greatly appreciated!
- 4TheKZ1000
- Visitor
05 Aug 2012 16:03 #540856
by 4TheKZ1000
Replied by 4TheKZ1000 on topic Just cleaned the carbs now my kz wont run
What did Clint Eastwood say “ MAN MUST KNOW HIS LIMITATIONS “
- Wristwist
05 Aug 2012 16:20 #540860
by Wristwist
Replied by Wristwist on topic Just cleaned the carbs now my kz wont run
Well after building countless small block Chevys I thought a set of motorcycle carbs would be gravy. Guess I was wrong :blush:
- Thank you received: 2829
05 Aug 2012 17:46 #540874
by 650ed
Replied by 650ed on topic Just cleaned the carbs now my kz wont run
Remember - when starting a cold KZ engine choke on full and do not touch the throttle. One other note, the carb bowls can be removed without removing the carbs. The tool below helps.
Attachment carbscrewdriver.jpg not found
- peter1958
- Banned
- Thank you received: 198
05 Aug 2012 18:09 #540878
by peter1958
Replied by peter1958 on topic Just cleaned the carbs now my kz wont run
I would look at vacum caps and vacum line
- Wristwist
05 Aug 2012 18:57 #540881
by Wristwist
Thanks Ed! Wish I woulda known that before. I finally got it to run and it was sounding good so I took it out for a short ride. All was good for a little bit but then it quit on me. I had to put the petcock on prime to get it back running, so I took off then a little later it quit again. I repeated the same process and got it running again. This time I left it on prime and it did fine. Anybody got any ideas???
- redneckcarrow
05 Aug 2012 20:49 #540891
by redneckcarrow
1980 kz 550 ltd stock
Replied by redneckcarrow on topic Just cleaned the carbs now my kz wont run
did you hook up vacuum line for petcook
- Wristwist
05 Aug 2012 21:21 #540894
by Wristwist
I just found the problem! Thank you redneck for suggesting the vacuum line. It was hooked up but it seems that when I set the tank on it pinched the line. Thanks for the help and suggestions everybody
- bountyhunter
- Thank you received: 337
05 Aug 2012 22:58 - 05 Aug 2012 23:00 #540916
by bountyhunter
Replied by bountyhunter on topic Just cleaned the carbs now my kz wont run
case closed, I was going to suggest fuel tank vacuum lock.
Last edit: 05 Aug 2012 23:00 by bountyhunter.
