i put a new jet in my carb and now its pouring gas
- Dodson
05 Aug 2012 00:10 #540790
by Dodson
TigerKiller
i put a new jet in my carb and now its pouring gas was created by Dodson
So I changed the jet. and now its pouring gas out of my over flow tube at the bottom of the bowl. I was wondering if I accidentally moved the floats I tried to be extra gentle . any help is greatly appreciated
TigerKiller
- wireman
- Thank you received: 299
05 Aug 2012 00:19 #540791
by wireman
Replied by wireman on topic i put a new jet in my carb and now its pouring gas
Check the float and needle valve to make sure its not stuck
- Dodson
05 Aug 2012 00:36 #540799
by Dodson
TigerKiller
Replied by Dodson on topic i put a new jet in my carb and now its pouring gas
How do I check the.needle valve is that was pulls up with the.slide?
TigerKiller
- Motor Head
- Thank you received: 391
05 Aug 2012 01:28 #540804
by Motor Head
Replied by Motor Head on topic i put a new jet in my carb and now its pouring gas
Put your bike year and model in your signature, next to the "tiger killer"
Float valve/ needle and seat has nothing to do with the slide. It is wear the float hangs and pivots, this valve and the float height controls the level of fuel in the float bowl. Very important to have the Correct fuel level in the float bowl. You can see the level of fuel by using a clear piece of tubing hooked to the drain on the float bowl, held up against the carb body with the Petcock turned to "Prime". It should be just below the mating gasket surface.
- Dodson
05 Aug 2012 04:49 #540809
by Dodson
TigerKiller
Let it pour wish the road and got it into third. I believe it was ny needle nit seated fully
TigerKiller
- 4TheKZ1000
- Visitor
05 Aug 2012 06:17 #540815
by 4TheKZ1000
Replied by 4TheKZ1000 on topic i put a new jet in my carb and now its pouring gas
Dodson wrote: Let it pour wish the road and got it into third. I believe it was ny needle nit seated fully
Attachment th_2012-08-05.jpg not found
- wireman
05 Aug 2012 06:29 #540816
by wireman
:woohoo:
Attachment imagesCANTRYQV_2012-08-05.jpg not found
:woohoo:
