I need a float level answer please
- Jhenry
04 Aug 2012 22:02 #540762
by Jhenry
I need a float level answer please was created by Jhenry
1974 Z1A, a great bike by the way. Yes, I admit it. I love an inanimate abject.
I suspect my float levels are off just a bit, especially in #1 carb. The stock 28mm Mikuni's. Too much fuel in that carb.
I know I need to do the clear tube test for exactatude, but that will have to wait. My manual states with the carb upside down I should have a 24mm float height above the carb body. My question is this. Should the 24mm (953 thousandths) be measured from the rim, or down into the carb further where the gasket sits.
I can get this squared away in the AM if I get a answer. Thanks guys.
- Thank you received: 2829
04 Aug 2012 22:19 #540766
by 650ed
Replied by 650ed on topic I need a float level answer please
Why wait on doing the clear tube test when it's faster, much easier, and waaay more accurate than doing the upside down; hit or miss guesswork thing? Ed
- Jhenry
04 Aug 2012 22:36 #540771
by Jhenry
Replied by Jhenry on topic I need a float level answer please
Because I need to ride tomorrow, so I need to get it as close as possible in the AM. I will fine tune it afterwards. Constructive criticism I can take, but an answer would be much more helpful at this point.
- wireman
- Thank you received: 299
04 Aug 2012 23:16 #540776
by wireman
Replied by wireman on topic I need a float level answer please
Its been so long since Ive done it that way im drawing a blank here also :blink:
- wireman
05 Aug 2012 00:07 #540788
by wireman
Does anybody have an old clymers manual?
i bet it would have a picture
- Motor Head
- Thank you received: 391
05 Aug 2012 01:30 #540805
by Motor Head
Replied by Motor Head on topic I need a float level answer please
Gasket Surface for float height measurement, not the rim. Once done, verify the fuel level with the clear tube test.
- Jhenry
05 Aug 2012 09:41 #540822
by Jhenry
Thank you Sir, I do appreciate it.
- Tomolu5
- Thank you received: 45
05 Aug 2012 12:20 #540837
by Tomolu5
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
Replied by Tomolu5 on topic I need a float level answer please
I did the clear tube without any special tools, just took my bowl to the hardware store, and found a tube that would thread into the drain hole.
Mine:
- kawasaki mike
- kawasaki mike
05 Aug 2012 19:38 #540887
by kawasaki mike
Am addicted to Z1's and kz 900's have an el camino, fly rc helicoptors and am strung out on horsepower.
Replied by kawasaki mike on topic I need a float level answer please
Measure fro the gasket surface as it sits in the carb roof of the carb , or the gasket surface below the floats if upside down. Plus or minus 24mm by (one mm)
