BS34 Adjustment
- 1000J
02 Aug 2012 03:48 - 02 Aug 2012 03:58 #540187
by 1000J
BS34 Adjustment was created by 1000J
Looking for some advice, I have an 84 Kz750 all stock/original condition right down to the factory 4-2 exhaust,stock air box and no engine mods, my issue is after the bike has been ridden and sits for 15-20 minutes it starts but stutters and seems to run lean for about a minute then no issues.Bike runs great through all rpm ranges after that,just seems like it needs partial choke every time after sitting a short time before riding again. Carbs have been rebuilt,synced,stock jetting/ needles. No other issues with the performance, it's just like starting it cold every time when it's actually hot.
Last edit: 02 Aug 2012 03:58 by 1000J.
- Motor Head
- Thank you received: 391
02 Aug 2012 09:49 #540216
by Motor Head
Replied by Motor Head on topic BS34 Adjustment
Before you say its carb related, check your valve clearances. Sounds like tight valves.
- 1000J
02 Aug 2012 16:58 #540296
by 1000J
Replied by 1000J on topic BS34 Adjustment
I'll look into the valves but I didn't have this issue before having the carbs done.It's a little better since I shimmed the needles up.
- Motor Head
02 Aug 2012 23:07 #540374
by Motor Head
Mixture screws not far enough out? What amount of turns from lightly seated are yours set at? Should be adjusted on each separately running when warm. Turn them in till the cylinder starts to lose RPM, then back out around 1/2 turn till it Idles nice on each. Some may end up quite different then others, depending.
- 1000J
03 Aug 2012 00:13 #540402
by 1000J
Carbs were done by wiredgeorge carbs,I haven't changed any settings since he built them except putting one shim under each needle which helped a little,these needles have no grooves.I just took the tops off each carb to remove the shims and noticed fuel above each needle in the slider part of the diaphgram.
