re jetting
- Landon22
01 Aug 2012 18:09 #540057
by Landon22
re jetting was created by Landon22
i have a 1983 kz550 and i have been told by plenty people that i need to re jet my carbs.. how do i do this? and what is the best kit? i dont want to take it to a shop because i cant get it started.. what is re jetting anyway?
- mark1122
- Keep twisting it
- Thank you received: 109
01 Aug 2012 18:35 #540061
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic re jetting
rejetting is replacing the current jets with dif sized jets. this would be done if u modified the bike in some way. like adding a header or individual air filters. these type of mods require rejetting to supply more fuel.
get the bike running before u worry about rejetting.
why do people tell u that it needs rejetting?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Landon22
01 Aug 2012 18:53 #540066
by Landon22
Replied by Landon22 on topic re jetting
Because i added pods air filters on the carbs and took the stock air box off. Where do i get a kit? and whats the best brand?
- mark1122
- Keep twisting it
01 Aug 2012 19:54 #540074
by mark1122
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
u dont buy a kit. u buy 1 size larger and try it . if that doesnt feel good enough u buy the next size up.
first u need to read up on carbs a bit. then jump in with both feet.
go to the top of the page and click on Filebase. in there click on not model-specific. look for files on rebuilding and tuning carbs.
on pg 2
there is a Simple_Jet_Guide .
a mikuni-vm-manual
kzrider.com/filebase/doc_download/349-mikuni-vm-manual
this 1 too
KZ_Slide_Carb_Tuning
PG 3
this is a good 1
KZ650_Changing_Jets
good luck. come back when u r an expert.
just kidding.
on pg 2
a mikuni-vm-manual
this 1 too
PG 3
this is a good 1
KZ650_Changing_Jets
just kidding.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Eddyv54
01 Aug 2012 20:14 #540079
by Eddyv54
Replied by Eddyv54 on topic re jetting
don't mean to HiJack but..
How do you remove the jets from the jet stems? I seem to be stripping the jet.. You can remove them, right?
- Thank you received: 2829
01 Aug 2012 20:31 #540086
by 650ed
Replied by 650ed on topic re jetting
When rejetting a KZ550 that has CV carbs, be sure to wear the right outfit....
Attachment french-garlic-garland-5575-p_2012-08-01.jpg not found
- Proxy
- 80% Human 20% Nuts/Bolts
- Thank you received: 46
01 Aug 2012 22:49 #540111
by Proxy
Take it from me cuz I found
If you leave it then somebody else is bound,
To find that treasure, that moment of pleasure,
When yours, it could have been.
1977 KZ650 B1 Being restored to original (Green)
1977 KZ650 B1 Original (Red) Sold
1977 KZ650 B1 Donor Bike for Parts
Replied by Proxy on topic re jetting
Just curious....these people who told you to rejet the carbs...were they the same people who told you to remove the airbox? Again just curious. There is a LOT of info here about Pods vs Airbox, it's a little after the fact but you may want to do a search with that term. Just to know what exactly you are dealing with.
- loudhvx
- Thank you received: 1616
02 Aug 2012 13:28 #540262
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic re jetting
If your bike is an 83 KZ550A, you have carbs similar to the KZ550H gpz. You may be able to use the Dynojet kit fro that bike, but it's not cheap. It's not really a task for a beginner.
1981 KZ550 D1 gpz.
Other links.
- Landon22
06 Aug 2012 15:54 #541015
by Landon22
Do i gotta re jet my carbs if i change the spark plugs to performancce spark plugs?
06 Aug 2012 15:56 #541016
by 650ed
What do you mean by performance spark plugs? Ed
- Landon22
06 Aug 2012 16:05 #541018
by Landon22
If you look on ebay kz550 spark plug there is s performance one.
06 Aug 2012 16:23 - 06 Aug 2012 16:24 #541023
by 650ed
No eBay APP ID and/or Cert ID defined in Kunena configurationIMHO it is very expensive snakeoil...
Last edit: 06 Aug 2012 16:24 by 650ed.
