1977 kz 650 float level
- 900#1
01 Aug 2012 14:54 #540007
by 900#1
1977 kz 650 float level was created by 900#1
vm26 carbs ....why is there no dry float height info anywhere ???????????????? i know about the clear tube trick- but there has to be a base height to start from ..JFC !!!!!!!!
- Thank you received: 2829
01 Aug 2012 15:02 #540010
by 650ed
Replied by 650ed on topic 1977 kz 650 float level
Are you sure your carbs are VM26? 1977 KZ650 models (both B1 and C1) originally came with VM24SS carbs. Ed
- Thank you received: 2098
01 Aug 2012 22:46 #540110
by Patton
32±1 mm
Replied by Patton on topic 1977 kz 650 float level
900#1 wrote: vm26 carbs ...dry float height info...to start from....
32±1 mm
- 900#1
01 Aug 2012 23:24 #540119
by 900#1
Replied by 900#1 on topic 1977 kz 650 float level
yep ...sorry that was an type-0--- vm24's
- gd4now
- Denco where did you go?
- Thank you received: 445
01 Aug 2012 23:37 #540121
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic 1977 kz 650 float level
OK for the vm24ss carbs the design fuel level is 30 +/- 1 mm. The clear tube level is 3.5 +/- mm.
1977 KZ650 B1
