- Thank you received: 2098
POPPING AND SPITING
- 4TheKZ1000
- Visitor
31 Jul 2012 22:38 #539866
by 4TheKZ1000
POPPING AND SPITING was created by 4TheKZ1000
MY BIKE IS MAKING SOME SOUNDS....AND IT AINT A PURRR.
IF I PUT MY EAR DOWN BY THE POD, I CAN HEAR A POP AND SPIT SOUND EVERY NOW AND THEN. I ALSO AM SMELLING ABIT OF FUEL?
THE CARBS ARE NEW RS34'S
THANKS
THANKS
01 Aug 2012 00:29 #539911
by Patton
Replied by Patton on topic POPPING AND SPITING
Whichever cylinder is spitting back through the carb might result from failure of the intake valve to completely seal. Which allows part of the combustion to escape through the intake port.
Sometimes a valve's failure to completely seal is caused by insufficient valve clearance. And may be especially noticeable when the engine has reached normal operating temperature.
- OldSchoolZ
- Thank you received: 33
01 Aug 2012 15:53 #540022
by OldSchoolZ
Remember, don't work on your bike so much you never ride it.
Replied by OldSchoolZ on topic POPPING AND SPITING
Yes what Patton said :laugh: but I would run a compression test and if low, pull valve cover and check valve clearances. I've heard bikes spit because they were too lean somewhere as well. Smooth bores hang at certain rpms where you are lean. Heck spray your intake boots also and check for leaks. Many things can cause spitting.
- bountyhunter
- Thank you received: 337
01 Aug 2012 16:35 #540037
by bountyhunter
Replied by bountyhunter on topic POPPING AND SPITING
Check ignition timing and timing advancer assembly.
And yes, they do pop and spit if they are lean. First thing I thought of when I saw the word PODS.
- mark1122
- Keep twisting it
- Thank you received: 109
01 Aug 2012 17:42 #540049
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic POPPING AND SPITING
what jets r u running? how many cc's?
the pilot screws on the RS carbs r only to be adjusted out to 1/2 turn max from there seats. be gentle when seating them, the tips break off easy.
try opening the pilots 1/8th turn at a time and see if the spitting stops. to set them properly, u turn them in or out until u achieve the highest rpm. then readjust the rpm with the slide height adjuster (idle adjuster).
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
The following user(s) said Thank You: 4TheKZ1000
