- Thank you received: 2
Carb-kit recommendations for KZ550-C3 1982 please.
- Bunty27
30 Jul 2012 19:51 #539612
by Bunty27
1982 KZ550 LTD
Carb-kit recommendations for KZ550-C3 1982 please. was created by Bunty27
I see one from Z1 enterprises here:
www.z1enterprises.com/ItemDetails.aspx?item=KL18-2462
There's another one here:
www.powersportsplus.com/parts/detail/aft...rket/XP-4101383.html
Thanks in advance.
Thanks in advance.
1982 KZ550 LTD
- loudhvx
- Thank you received: 1616
02 Aug 2012 13:39 #540264
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic Carb-kit recommendations for KZ550-C3 1982 please.
Get the ones at Z1 enterprises. THe listing at powersports is not right. THe H and D model Gpz's can't use the same kit. Who knows what you would get.
1981 KZ550 D1 gpz.
Other links.
The following user(s) said Thank You: Bunty27
- Bunty27
09 Aug 2012 23:27 #541649
by Bunty27
1982 KZ550 LTD
Replied by Bunty27 on topic Carb-kit recommendations for KZ550-C3 1982 please.
After looking at my carbs again, I decided to only replace all the float assemblies because I know I have at least two bad float pins. I'll hold off on complete carb build for now.
1982 KZ550 LTD
- loudhvx
10 Aug 2012 13:19 #541751
by loudhvx
1981 KZ550 D1 gpz.
Other links.
When you replace the float valve seats and needles, you will need to reset the float heights. The aftermarket needles are slightly longer. Here's a page on how to set it in the ballpark, then you can double check them with the clear-tube method.
home.comcast.net/~loudgpz/GPZweb/TK22mai...stmentsAndMaint.html
1981 KZ550 D1 gpz.
Other links.
