- Thank you received: 88
carb ID
- GregZ
28 Jul 2012 08:38 - 28 Jul 2012 08:42 #539197
by GregZ
carb ID was created by GregZ
Last edit: 28 Jul 2012 08:42 by GregZ.
- 4TheKZ1000
- Visitor
28 Jul 2012 08:39 #539198
by 4TheKZ1000
Replied by 4TheKZ1000 on topic carb ID
no phtos
- 4TheKZ1000
- Visitor
28 Jul 2012 08:49 - 28 Jul 2012 08:50 #539201
by 4TheKZ1000
check here on on the silver carb flange this side or the other for a letter and number.
Attachment carbs111.jpg not found
Last edit: 28 Jul 2012 08:50 by 4TheKZ1000.
- gd4now
- Denco where did you go?
- Thank you received: 445
28 Jul 2012 13:15 #539226
by gd4now
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
Replied by gd4now on topic carb ID
t is very hard to tell from the picture you have posted. You need to look for the ID stamped on the flange just below the choke/enricher lever. That is the fastest way to ID them. You could also measure them. You could also look at the needles as they may also (if still stock) give you an idea what they began life as. Do they have both an air screw and pilot screw? It is my understanding that the 26s from Suzuki's have both.
IIRC all of the 26s that come stock on the KZs had dual fuel inlets, but I could certainly be wrong. But if that is the case then they either are the larger 28s or they were not stock on a KZ.
1977 KZ650 B1
