- Thank you received: 10
Push - Pull Cables
- 4TheKZ1000
- Visitor
27 Jul 2012 21:56 #539118
by 4TheKZ1000
Push - Pull Cables was created by 4TheKZ1000
My question is: which hole is the push and pull on the throttle handle?
If I had to guess, the top hole on the throttle handle would be the pull and the lower hole would be the push.
thanks
thanks
- pig9r
27 Jul 2012 22:09 #539122
by pig9r
Replied by pig9r on topic Push - Pull Cables
The way I understand it, It really doesn't matter. The difference is in the length of the pieces that screw into the handlebar controls. One is longer than the other so you can screw them in without interfering with each other. I would put the shorter one closest to the gas tank so it is less likely to hit the tank.
- 4TheKZ1000
- Visitor
27 Jul 2012 22:21 - 27 Jul 2012 22:24 #539123
by 4TheKZ1000
Replied by 4TheKZ1000 on topic Push - Pull Cables
it does matter how you go to the carbs. they want the pull on lower arm of carbs wheel with the push on top. this is why I need to know the orientation of the throttle handle cables.
Last edit: 27 Jul 2012 22:24 by 4TheKZ1000.
- Thank you received: 2829
27 Jul 2012 22:26 - 27 Jul 2012 22:28 #539125
by 650ed
Replied by 650ed on topic Push - Pull Cables
It does matter. The hole toward the front of the handlebar is the "pull" cable so as you twist the throttle in the open position back toward the rider (counter-clockwise) it is pulling that front cable which in turn is pulling the carb slides open. When you twist the throttle closed (the other direction) it is actually pulling on the so called push cable (the cable nearest the rider) which pulls the carbs shut. When you open up the throttle control on the handlebar I think you will see what I mean. Ed
Last edit: 27 Jul 2012 22:28 by 650ed.
- 4TheKZ1000
- Visitor
27 Jul 2012 22:38 #539126
by 4TheKZ1000
thanks ED,
I have never been exposed to a push-pull....bike came with one cable.
- pig9r
27 Jul 2012 23:47 - 27 Jul 2012 23:54 #539141
by pig9r
If you buy a set of cables from someone like motion pro they will both be labeled push/pull. The only difference will be the length of the parts I mentioned earlier.
Patton's post here explains it a little better than me.
kzrider.com/forum/5-chassis/531170-can-t...stead-of-pull#531170
Last edit: 27 Jul 2012 23:54 by pig9r.
